Closed Thread
Old 10-30-2012, 08:12 PM   #6426
suzq044
Resident Photoshop Nerd
suzq044's Avatar
Re: What did you do to your truck today?
Parked him in his new storage space until we finish the engine, in our new city of Phoenix.
PJ - 1966 C10 Panel --
Max˛ - 1964 Jeep Wagoneer Panel-delivery -- Waiting his turn
suzq044 is offline
Old 10-30-2012, 08:57 PM   #6427
willyp
willyp's Avatar
after driving my truck for 4 years with no gas pedal i found a easy fix at the good guys show this past weekend. welded a nut to the end of the arm.... i like it and it was easy and cheap.
The price of cool aint cheap.
willyp is offline
Old 10-30-2012, 10:13 PM   #6428
dantimdad
dantimdad's Avatar
I really like that solution!
I just might borrow it.
Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla
Matt. 6:27 "Who of you by worrying can add a single hour to his life?”
http://www.67-72chevytrucks.com/vboa...=507266&page=2
dantimdad is offline
Old 10-31-2012, 10:31 AM   #6429
vin63
It's Better With Nitro
vin63's Avatar
Finished welding up and smoothing out the last holes in the cowl area, rear of cab interior, and repair of the top of the dash (replaced speaker grill and fixed dents in the dash). This is the last repairs of literally 100s of holes the PO drilled throughout the cab and floor. Time to put the cab back on the chassis and get it ready for real bodywork and paint...
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline
Old 10-31-2012, 10:51 AM   #6430
1963c-10
1963c-10's Avatar
willp p.....cool mod. Ill get with you this weekend if your going to be around. Will be doing a bonfire/bbq at my place Sat night if you'd like to come out.
1964 Short bed trailer
1963c-10 is offline
Old 10-31-2012, 03:21 PM   #6431
kieth
kieth's Avatar
Originally Posted by Snowbound View Post
Bought the power steering kit from the Captain and picked up a 1.25" front sway bar from Pick and Pull. Ordered up the Energy Suspension bushings for it and I'm going to finish painting it up today.
I was thinking of using that silver Hammertone paint on the sway bar to give it some colour. How durable is that stuff?
Brian
i DID THE SILVER ACCENTS ON OTHER ITEMS, IT DOES HELP TO DRAW OUT SOME DETAIL. KIETH
http://kieth.smugmug.com/Trucks/66-G...8634&k=cFvxQKn
Now that I look back on it, we might have gotten a little carried away but it looked good at the time. Kieth
kieth is offline
Old 10-31-2012, 08:59 PM   #6432
Bomp
Bomp's Avatar
I welded in the support section on the underside of the cab stretch project.
Bomp is offline
Old 10-31-2012, 09:28 PM   #6433
willyp
willyp's Avatar
thanks for the invite, ill be here all weekend. give me a ring.
willyp is offline
Old 10-31-2012, 09:54 PM   #6434
markeb01
Senior Enthusiast
markeb01's Avatar
Took the truck out this morning to shoot a few photos, and discovered the pesky and irritating windshield trim squeak had returned. So this afternoon I spent another couple hours with a blade like jewelers file and opened up a good size gap between the two upper pieces. Hopefully this will be the last time it needs attention because it's miserable working on that spot with the hood in place.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
markeb01 is offline
Old 10-31-2012, 10:05 PM   #6435
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Talking Re: What did you do to your truck today?
Well seeing everyone working on their trucks here lately made me do a little tinkering while she's down.
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline
Old 10-31-2012, 10:06 PM   #6436
1Bad62Pro/Street
Last pic.
Old 11-01-2012, 01:41 AM   #6437
fryer1979
Redneck Hillbilly
fryer1979's Avatar
Went out to try and fire her up for a little drive.....and no start. This carb is junk, and I'm tired of messing with it. So I guess she sits until I can get the Caddy engine in, or I figure something else out.
fryer1979 is offline
Old 11-01-2012, 08:48 AM   #6438
kieth
kieth's Avatar
Wow Mark looking "GOOD"
kieth is offline
Old 11-01-2012, 09:10 AM   #6439
Improbcat
Improbcat's Avatar
(technically this weekend, but this is the first chance I've had to post it)
Replaced the valve cover & pushrod cover gaskets. Repainted all the pieces I took off. Since I can't find the correct engine color I went with GM blue.
Started laying sound deadener down, I've only done the middle area as I still need to finish rust repair & repainting at the sills, and get the rest of the old insulation off the firewall.
Improbcat is offline
Old 11-01-2012, 02:47 PM   #6440
1Bad62Pro/Street
A few more today...
I'm using Cold Drawn Steel. All steel used on my truck is Cold Drawn Steel.
Will add more of the progress later.
Old 11-01-2012, 02:55 PM   #6441
cortcomp
cortcomp's Avatar
Just picked up my first pre-80's truck in fresno yestersay, driving it back to ohio until sunday
66 with 3pd, 327, 3 gas tanks, sbw, long bed.
cortcomp is offline
Old 11-01-2012, 04:38 PM   #6442
markeb01
Senior Enthusiast
markeb01's Avatar
Welcome to the forum, and good luck on your journey!
markeb01 is offline
Old 11-01-2012, 08:49 PM   #6443
66farmer
66farmer's Avatar
I finish the 2 1/2 day puzzle today. I think I was only able to lay (2) complete sheets the rest was make a template cut and lay. Then go back and tape all the seames and there was alot of them.
66farmer is offline
Old 11-01-2012, 08:53 PM   #6444
CRGRS 66
CRGRS 66's Avatar
Sure looks like it was worth all the effort!!!!! I foresee lowered voices on the highway in your future
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline
Old 11-01-2012, 08:54 PM   #6445
CRGRS 66
CRGRS 66's Avatar
A little bummed today, thought I would see my CPP order today... most likely next Tuesday now, the bright side is that I am not really ready for it anyway
Craigerrr
CRGRS 66 is offline
Old 11-01-2012, 08:57 PM   #6446
markeb01
Senior Enthusiast
markeb01's Avatar
Wow that looks beautiful.
markeb01 is offline
Old 11-01-2012, 09:16 PM   #6447
pdxhall
pdxhall's Avatar
Great job, man! Your truck is really coming along. I can't wait to see it finished.
pdxhall is offline
Old 11-01-2012, 09:19 PM   #6448
ABX131
ABX131's Avatar
My son took our 63' to high school autoshop for a brake job...$40 in parts and free labor including turning the rotors and drums and we have a truck that actually stops! Good job kids! The shop teacher likes the older vehicles because they make great teaching projects because they are simple..
ABX131 is offline
Old 11-01-2012, 10:19 PM   #6449
willyp
willyp's Avatar
took the truck to the BBQ today at work. one of my joes took these...pretty cool. then the drivers window got stuck down, had to fix that when i got home.
willyp is offline
Old 11-01-2012, 10:34 PM   #6450
boat
boat's Avatar
weld in fender patch http://67-72chevytrucks.com/vboard/a...1&d=1351823657
STEVES 63 BUILD http://67-72chevytrucks.com/vboard/s...d.php?t=412554 GIBSON63 YouTube channel https://www.youtube.com/user/1gibsonl4
boat is offline
Closed Thread
