10-31-2012, 12:06 PM | #1 |
drop spindle selection
Hey guys wanna lower the Blue Heeler 5" front and 6 rear with blocks and notching the frame. i see most spindles they sell are 2 1/2 drop will it be to low? i currently have 3" front and 4" rear if someone has a couple pic's to show it would be helpful. thanks.
10-31-2012, 02:20 PM | #2 |
Never Ending Projects
Re: drop spindle selection
CPP's modular spindles are a 2" drop versus most which are 2.5".
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
10-31-2012, 02:39 PM | #3 | |
67-72 parts collector,…
http://67-72chevytrucks.com/vboard/s...d.php?t=507575
10-31-2012, 04:21 PM | #4 |
the possibility of 5 in the front also depends on what size tires you are running or weather you want to slow down for dips in the road.
10-31-2012, 05:09 PM | #5 | |
Sat on the phone for 17 minutes on hold the first time then called the next day another 15 minutes waited a week and after 10 minutes i just hung up. aftr looking in catalog they seem to be price higher than other companys |
10-31-2012, 05:11 PM | #6 |
10-31-2012, 06:24 PM | #7 |
This page will give you a glimpse of the different ride height. This guys are great to work with and their parts are top notch!
http://www.earlyclassic.com/Tech.asp...=Stance+Photos
Poor and content is Rich...and Rich enough! - William Shakespeare 1966 C10 Custom Cab "Luigi" Big Window - SWB Fleetside 350 V-8 - Powerglide My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894 |
10-31-2012, 08:17 PM | #8 |
Here is a picture of my truck now.
11-01-2012, 06:41 AM | #9 |
Watch out for your cornhole !
11-01-2012, 09:20 AM | #10 |
Did you have to trim the a-arms at all? which spindles did you use?
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
11-01-2012, 09:24 AM | #11 |
No arm trimming required. The front wheels were 7 inches wide with 3.5 inch backspace. Cleared just fine.
Spindles, I ordered from Summit. I ordered CPP spindles from them because they were the cheapest and Summit had them in stock and none of the CPP typical BS that so many people go through. When I got the spindles and opened the box, they were Western brand castings. CPP sells them under their name. |
11-01-2012, 10:27 AM | #12 |
I want a set of spindles that fit my factory stuff with a 2" or 2-1/2 drop. I don't need all the big brake stuff, big calipers and all the crap that goes with it. i'm running 15x8 rallys is there gonna be a clearence problem or am i good?
11-01-2012, 10:48 AM | #13 |
Yes, the modular spindles cost more becuase they will allow you to convert to larger brakes if you ever want to. The caliper mount is swapable unlike the cast in styles like Tx Firefigher shows above.
Here's a pic with 15x8, 4.5" BS steel wheels and the clearance between the arm lip and wheel. That extra .5" of other spindles will likely cause clearance issues. Sorry for the blurry pic. Here's a pic of the modular spindle.
11-01-2012, 11:36 AM | #14 | |
11-01-2012, 11:46 AM | #15 |
And, you have to convert to disc brakes to run spindles, correct?
11-01-2012, 11:53 AM | #16 |
Yeah i'm putting on disc brakes all 69-70 stuff.
11-01-2012, 12:19 PM | #17 |
From a number of posts, it does seem that 15x8" wheels with 4.5" BS will hit the lip of the lower arm with a 2.5" drop. I personally have not tried so I am only relating to what others have found. If you have less BS or a narrower wheel, 2.5" drop will work fine.
I have my '68 with the 2.5" spindles and have a set of 15x8" rallys I want to use but haven't test fitted them. To be safe, I picked up a pair of 15x7" rallys, just in case.
11-01-2012, 12:57 PM | #18 | |
11-01-2012, 01:08 PM | #19 | |
CURRENT & PAST CHEVY TRUCKS 60 C-10 Apache short step side 62 C-10 short step side 66 GMC Long bed fleet side 305 V-6 77 C-20 Custom Deluxe (Blue Goose) |
11-01-2012, 01:26 PM | #20 |
Somewhat irrelevant but what is the diameter on the hub of those 6 lug disc brakes? Looking to clear a rim with a 3" center hole. thanks
11-01-2012, 01:29 PM | #21 |
As for the CPP Modular spindle, keep in mind you also have to buy the bracket to adapt your stock brakes to them.
11-01-2012, 01:42 PM | #22 |
Man what a joke!!! if the 2 1/2 will work then i will buy them. just trying to finish this stage and move on to changing out manual trans to auto trans.
11-01-2012, 02:22 PM | #23 |
OK, so im confused ( no real shock there)
I have 71/72 discs now, I have 15*8 rallyes. do I go with the 2", the 2.5" or the modular spindles? I do not want to mess up my a-arms or my rallyes.
11-01-2012, 02:27 PM | #24 |
From the look of the picture above, you will want to go with a 2" spindle, cause the 2.5" will put the a-arm right against the wheel.
11-01-2012, 03:34 PM | #25 |
well for what it's worth just got off the phone with CPP and they did say 2 1/2 drop spindle will work with an after market wheel but not with stock rim. i grinded the guy for atleast 15 minutes on this and he assured me there is no problem part#CP4S2 thats using you stock stuff tie-rod ends 68-70 rotors and stock calipers.
