![]() Join Date: Jun 2003
![]() ![]() If anybody who has 'the secret' to removing those well engineered almost BLIND bolts .... I'd really appreciate the helpful ideas. Thanks, 72longbed |
#2 | |
Re: Removing Front Drive Shaft 72 K20???
Transmission cover?????? Do you mean the Pan? These bolts are no where near the pan. They go in from the back of the transfer case yoke.
I have an NP205. Confused on your advice?? |
#4 | |
two wrenches, front and back of the flanges, then roll the truck alittle to acess the other two bolts
I agree, take the high hump out and you will be much happier. I had to do this and it made it much easier.
1969 4x4 Nothing beats a good rock drill and some dynamite |
20' Daredevil (Ret)
![]() Join Date: May 2003
Don't shoot me.... when I removed mine a few years back, I just used a couple endwrenches and took a whole lot of very little bites. Didn't have to remove anything for access, just laid under the truck on a creeper.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
#7 | |
A great reason to use the BEST u-joints you can find when you put it back in! ![]()
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
![]() Join Date: Feb 2007
ah, you must have a fixed yoke? i have a flanged front output on my 205 and the four bolts zip off with a gear wrench quick. hardly a dirty finger to remove much less a dirty word
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
#9 | |
OOOOOOOOOOHHHHHHHHHHHH!!!!! I get it nowwwww. "Death from above!!
I'll drop in from the attic on it's ass!! Ok. I'll take a look tomorrow. I have a B & M Truck MegaShifter in there above the transfer case. I already did some metal patch panels in the past in that area, so maybe I can remove some of my previous 'work' and rain in on it's stubborn self from above. I put the driveline together originally without a cab on the frame. Access was, how you say, EEE-ZZZ, at that time. ![]() ![]() I must have torque'd those little suckers? Thanks for the great ideas. I'll have at it in the AM. 72 over and out. ![]() |
Windy Corner of a Dirty Street
Pulling the tunnel cover just to get the shaft out is too much work. I have one of those old style shafts in my ’78 K10 as well (it’s a ’72 NP205) and they can indeed be a hassle to bolt in and out. I just hold the ½” wrench up to the bolt head then turn the shaft. Turning the shaft instead of turning the wrench makes it go much faster. I’ve probably had the front shaft out of this truck 20 times in the past 16 years since the 205 was installed and have gotten pretty fast at it.
Hold the wrench at the bottom most bolt right above the skid plate then turn the shaft while holding the wrench. You can usually get ¾ turn with each rotation of the shaft before you have to reposition the wrench again. Once the first bolt is backed out of the shaft rotate the shaft to get the next bolt pointed to the bottom. Don’t be surprised if the bolts will not come completely out as most of time the bolts will hit the yoke slash shield and not come all the way out but you can still drop the shaft with the bolts hanging in the yoke. This goes a bit faster if the skid plate is out of the way. ![]()
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
#12 | |
20' Daredevil (Ret)
Dirt man,
I see you have the SM465 trans ... I have a 700R4 in there and it makes things even tighter next to and around that transfer case output yoke. So lay a 1/2" box wrench (maybe about 6" long) in there so it is on the head of a bolt and against the crossmember or other solid object, (don't have a shield), then turn shaft to break loose the bolt? Right? Ok ... I'm working alone and on the ground, so I want to get it right the first time. Do you guys suggest that I re-aatach the front U-joint, jack up the front wheels to be able to turn the shaft ... or can I turn that unattached shaft easily enough to break them loose? Thanks for your feedback on this. Oh, by the way ... how much travel in the front slip-yoke should there be when the truck is sitting on the ground? I have heard to have it in the middle of its range of slip-joint length ... is that the spec. on this? Thanks. 72 |
I don't see where auto vs. manual really matters. It is a tight squeeze either way as the distance between the yoke and tcase doesn't change. My old '72 K5 Blazer with a TH350 was no harder or easier to drop the shaft
#15 |
Ok Dirt ... I won't argue with you.
![]() Any opinion on my questions above? Thanks. 72 |
#16 |
The driveshaft will turn easily. It should turn freely without jacking the front end up. Keep the transfer case in 2wd, and make sure the front hubs aren't locked.
#17 |
UPDATE: Front shaft OUT!
Took out the hump .... low and behold there it all was, starring right back up at me. Did it on the ground (in the cab mostly), by myself, no jacks, no muss ... no fuss. One thing I will pass on to others who want to do it this way. I was lucky that my 'wall to wall' carpet already had a split right down the middle at the center of the hump. This did make it a lot easier to just part the carpet and get in there to remove the bolts for the hump. I had previously cut the carpet in that area to do some sheet metal repair on the hump, and install the B & M shifter. So ... if you have nice carpet in your truck ... be prepared to remove it first to do this, or put a cut from the firewall edge all the way back to under the seat above your hump (not the hump on your back, the one in the truck ![]() I will need to find more of the reflective heat blanket material I had installed over the hump ... I kinda cut it up pretty bad to remove it too. So the hump will stay unattached until I get my driveshaft cut and re-install it. I do agree, to have the shaft throughly inspected while out to take care of any problems at this time, and to use all high quality H.D. Spicer parts to repair. Thanks to all for the great ideas ... I hope this Thread can help others in the future too. 72longbed Last edited by 72longbed; 10-28-2012 at 10:11 AM. |
#18 | |
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
#19 |
Probably a hundred differant ways to solve the problem, they are all right, just differant degrees of right. Or should i say, one is righter then the other, take your pick....
#20 |
One more thing I will do different is leave the shaft attached at the front diff. until I have the rear bolts loosened/out. It really helps with ability to support the shaft and to be able to rotate it while working on the back bolts.
Live and learn .... I usually learn the hard way. ![]() ![]() 72 |
#21 |
i just had the same question a couple weeks ago, did it the old mans way and laid on my back cussing for an hour.
#22 |
x 2 on cleaning the bolts and the t-case yolk makes all the diference next time around
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
