Old 10-30-2012, 05:50 PM   #1
oldno7
oldno7's Avatar
what size rims for 67
i know the 67 rearends are shorter than the 69-72s what size backspacing do i need i would like to run 20x10s
Hi everyone, It's nice to know there's other people just as crazy about these old trucks as I am.
oldno7
oldno7 is offline   Reply With Quote
Old 10-30-2012, 06:03 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: what size rims for 67
Stock suspension?
Static Dropped?
Bagged?
Keith
Convert to disc brakes.
Old 10-30-2012, 06:24 PM   #3
Pro Performance
Pro Performance's Avatar
^^^^^ Yep, those are the things we need to know. If it's static dropped, how much?
Pro Performance is offline   Reply With Quote
Old 10-30-2012, 09:35 PM   #4
68Stepbed
68Stepbed's Avatar
Also if it's a fleetside or stepside.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 10-30-2012, 09:47 PM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Maybe this'll help: My '69 is static-dropped 2.5/4.0. The rearend width is the same from '60 thru '69. I run 15x10's on the rear, with a 5-inch backspace. The tires are 275-60x15's. You can find the diameter of this tire on various websites and compare that diameter to the diameter of the tires you intend to run on those wheels you like. I have a fleetside and have never had any issues with the tire contacting the inside of the wheel opening.....
Member Nr. 2770
Old 10-31-2012, 05:51 PM   #6
oldno7
oldno7's Avatar
its a 4-6 drop spring and a fleetside
oldno7
Old 10-31-2012, 05:54 PM   #7
Pro Performance
If you are looking for 20's, then a 20x8.5 will be good with a backspace of 5.25" - 5.5". Out back a 20x10 with 4.75" backspacing.
What diameter are you wanting? Were you in search for a custom built wheel or ????
