Old 02-21-2012, 02:01 PM   #126
57picupnewbie
'57 Rosa
57picupnewbie's Avatar
Re: My '57 Truck Build "Rosa"
thanks guys! 67step, that frame should work fine. Post some pics. I am buying my plasma cutter so body work begins. Already started with the smothing of the firewall. MAN THERE IS ALOT OF HOLES....lol
My '57 Truck Build "Rosa" (Current Project) http://67-72chevytrucks.com/vboard/s...21#post4118721
2003 Dodge Dakota 4X4 (Daily Driver)
Only two defining forces have ever died for us: CHRIST died for our salvation and VETERANS died for our freedoms. Glorify CHRIST and thank VETERANs
Dru~ USN Retired
57picupnewbie is offline   Reply With Quote
Old 03-08-2012, 07:46 PM   #127
57picupnewbie
'57 Rosa
Dropped in motor today for the first mock-up. I needed to check the firewall clearance for the distributor. Found out I have plenty of room thanks to the EZ Chassis Swap. Todd, at the school is having to cut his firewall back to allow room for his distributor. He did not go with the EZ Chassis Swap Kit. His cab sits lower. Now I can pull it back out and continue filling holes in the firewall.
Dru~ USN Retired
Old 03-09-2012, 01:20 AM   #128
Kim57
Kim57's Avatar
That color combo looks real nice.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 04-25-2012, 08:52 PM   #129
57picupnewbie
'57 Rosa
Thanks Kim.
I have not been on in awhile but I wanted to update. I have been practicing welding since it is new to me. I bought the Eastwood 135. I like it due to really being able to contol the heat. I also, just ordered and got the plasma 110/220. I have learned a few things.
1. You cannot rush yourself when welding or grinding.
2. Grinding welds WILL make you a better welder.
3. Skip around and let cool.
Alot have said to work on one area at a time. Due to my lower back problems, I have three areas I am working. This allows me to stretch and have different positions. They are the holes in the firewall, the hood and the major part which is the driver's side step area. I have missed all you guys and hope to now be caught up and back on regularly.
Dru~ USN Retired
Old 04-26-2012, 12:18 AM   #130
Kim57
Kim57's Avatar
Looking good.
I hear you on the back problems. Just take it slow and steady and you'll get there.
Kim
My build thread
Old 04-26-2012, 11:30 AM   #131
Russell Ashley
Russell Ashley's Avatar
Looks like it's coming along good, good to see you back at it. Keep the pics coming.
I have to wonder, did all PO's of TF trucks just like to make holes in the firewalls? It seems like the first thing most of us did when we started was to fill a bunch of extra firewall holes, LOL.
Russell Ashley is offline   Reply With Quote
Old 04-26-2012, 02:04 PM   #132
_Ogre
_Ogre's Avatar
definitely
i too have problems working low, i solve that by working on my cab raised 4 ft up
i had a forklift to work on but any platform would work
i see you use a die grinder for cutting, if you need something a little faster and aggressive
try using a 4'' electric grinder with 5'' cutting wheels. that all i ever use anymore
harbor freight sells grinders cheap, buy 2 they're real cheap
5'' cutoff wheels last 2-3 times longer than the 4'' wheels
shop air compressor timer
Old 05-01-2012, 04:20 PM   #133
57picupnewbie
'57 Rosa
Thanks Kim, we will do.
Russ, I do believe we all have either filled all those holes or just covered them. Man there is alot of them. I tell you, drilling spot welds just is no fun either. They sure had fun putting those in at the factory...lol
Orie, I do have a 4" grinder (electric) that I grind my welds with. I will have to give it a try. I just have more control with the die grinder in small tight spaces. It is nice to chat with all of you again. Thanks.
Dru~ USN Retired
Old 05-15-2012, 03:13 PM   #134
55Cameo
55Cameo's Avatar
Very nice build going on here. Like the progress you have so far and the frame swap is coming out really nice
Build thread:55 Cameo R!! http://67-72chevytrucks.com/vboard/s...d.php?t=519851
55Cameo is offline   Reply With Quote
Old 09-03-2012, 05:30 PM   #135
Russell Ashley
We haven't seen an update in a while. Anything going on?
Old 10-20-2012, 02:43 PM   #136
Russell Ashley
No posts in three months. What's happening? I hope the back problem is not what stopped the progress.
Old 10-31-2012, 04:36 PM   #137
57picupnewbie
'57 Rosa
Hey guys! I apologize for the absence. Down in the back some and also involved with my boys and their activities. My dad is also getting older and I have been spending some time with him. Spent too much time away while floating on the ocean with "Uncle Sam". I don't know how much longer I will have him around. Anyway, I am slowly getting back to the ole girl. I have the firewall holes welded up. Finishing up grinding. I have started fitting driver's step and rocker patch panel. I had posted pics previously. I will post new pics when I can. Hey Russ, thanks for asking. I have missed you guys. I have started reading back trying to catch up with all of your builds. Bam and Ogre your builds are awesome. Great work!
Dru~ USN Retired
Old 10-31-2012, 08:16 PM   #138
72BLUZ
72BLUZ's Avatar
slowly but surely it is taking shape!!!!!!!!!!!
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream.
It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan
72BLUZ is offline   Reply With Quote
Old 11-13-2012, 07:11 PM   #139
57picupnewbie
'57 Rosa
Okay guys, time for an update. I cleaned my shop up and organized all my tools AGAIN last week. (Something about having a 7 year old and tools falling off the boards into floor...lol). Today, I finished massaging the lower hinge pocket panel. Hopefully, I can tack it tomorrow. I also, was able to remove the old, inner hinge pocket panel. Any of you guys that have replace these, should know that they are a B***H to get out and to get the repops fitted. I was able to get the area cleaned up fairly nice. I will take pictures tomorrow. It really feels nice to get back in the shop.
Dru~ USN Retired
Old 06-20-2013, 08:43 PM   #140
57picupnewbie
'57 Rosa
I know it has been a long time since you guys have heard from me. After "honey-dos", a new roof on the house, and a death in the family I think I am finally back on track. It really feels good to get back at it. I have been practicing my welding along the way which I needed desperately anyway since I am a beginner anyway.
I left off with the driver step removed and I was fitting the lower hinge pocket. I then discovered that the "Inner Step Panel" (there is no name for this because it is not reproduced) needed to be replaced due to being rusted some. Therefore, I had to go out on a limb and make one. This was new territory for me. It went better than I thought. Picture with the Yellow Arrow is the panel I am referring to. Here are the pictures for you guys.
Dru~ USN Retired
Old 06-20-2013, 08:46 PM   #141
57picupnewbie
'57 Rosa
After I finished this panel, I re-measured and test fitted the lower hinge pocket again. Everything was good so I tack welded it. We are making progress now.
Dru~ USN Retired
Last edited by 57picupnewbie; 06-20-2013 at 08:47 PM. Reason: Photo did not attach
Old 06-20-2013, 09:03 PM   #142
57picupnewbie
'57 Rosa
I then moved around and marked and removed the Outer Hinge Pillar. The Inner Hinge Pillar was completely rusted out and missing (Go Figure)! After, Cutting and tweaking the reproduction Inner panel, I was able to get it to fit properly and ready to weld in. I check my fit for the outer panel one last time. Something told me to check the measurements on the Door Hinge Panel again. I am glad I did. WOW! Even with all the bracing, the cab corner had dropped on me 1/2". I only notice this after placing the step in to see what it would look like. One measurement was fine. However, Top door bolt to step measurement was off by the 1/2". Picture shows correction with jack bringing it back up to normal position. Now, I have a gap to fill in. I am just glad, I caught ii before I welded it all up. Fill you all in more in a few days.
Dru~ USN Retired
Old 06-21-2013, 12:12 AM   #143
Kim57
Kim57's Avatar
Looking good. Keep the pics coming.
Kim
My build thread
Old 06-21-2013, 07:20 PM   #144
57picupnewbie
'57 Rosa
Thanks Kim! It really feels good to be back at it.
Well, I went back out to address the 1/2" gap I was left with due to the cab corner dropping on me. So (pic 1) is what I was left to deal with. I did not like the idea of just welding in a patch due to this being a high stress area with the door weight and the weight of a person stepping out. So, I decided to make a back plate and spot weld it in first. This would add extra strength between upper and lower parts. See (pic 2). I then added in the 1/2" small patch and welded it up. End result is (pic 3). I think it turned out fairly nice for a novice. After, I get the inner and outer hinge pillar panels in that puppy is not going anywhere. I put the step back in place to check the fit and it is still on track (pic 4). It will not get tacked until I get the rear cab corners done.
Well, enough for tonight. I am tired and wife has steaks on the grill. You guys have a good night.
Dru~ USN Retired
Old 06-21-2013, 07:52 PM   #145
Kim57
Kim57's Avatar
That came out real nice.
Kim
My build thread
Old 06-22-2013, 08:13 AM   #146
Russell Ashley
Good to see you back, I've been wondering where you've been. The patch looks good.
Old 06-25-2013, 09:46 AM   #147
dubie
dubie's Avatar
i'm looking forward to seeing the front sheet metal on and seeing how the wheels fit inside the fenders
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 06-25-2013, 01:48 PM   #148
_Ogre
_Ogre's Avatar
i like how you shaved the firewall but kept the original ridges.
did you think of shaving the standing seam on the firewall?
this
vs this?
Old 06-25-2013, 06:50 PM   #149
57picupnewbie
'57 Rosa
Kim - Thanks, I was proud of it.
Russ - It is good to be back! After completing the patch, I felt like I had actually accomplished something.
Dubie - I will be glad to be at the point of having the firewall complete. Filling the holes was quite a learning experience in welding for me. I blew thru a lot of metal as I was learning. As for the wheels, well those may be awhile.
Ogre - My old friend! I was planning on a look like yours originally. Shaving the standing seam (due to mine being bent) and keeping the original ridges. However, Since, I have found a look that I just fell in love with. It is a sheet of polished stainless steel on the firewall that mirrors the engine. It would be awesome for car shows I think. I attached the picture for you guys to see.
Dru~ USN Retired
Old 06-25-2013, 06:56 PM   #150
57picupnewbie
'57 Rosa
Today, I spent almost 3 hours tweaking and adjusting the inner pocket panel. As you all know, not all reproduction parts fit "as advertised". I had to snip, and cut, and grind. I bent and hammered but it sits in there flat and smooth now. I finished welding it in and all is good. The only problem I have is my OCD is kicking in and I am having problems getting to the welds to dress them up. Now, I know these welds are going to be concealed and no one will ever see them. However, I know they are there. They may not be the most professional welds out there but they are mine and they will be the best that I can do. More tomorrow!
Dru~ USN Retired
