Old 10-31-2012, 02:58 PM   #1
JohnJ
Iginition Lock on 67 Suburban
I just acquired a 1967 GMC Suburban that did not come with keys. I have not been able to remove the ignition lock, very frustrating. I have been able to loosen the ring that holds the ignition lock in the dash but after a few turns, it just spins around. Can anybody give me the trick to remove the lock without the key?
JohnJ is offline   Reply With Quote
Old 10-31-2012, 04:15 PM   #2
s_nova69
Re: Iginition Lock on 67 Suburban
Cut it out with a grinder or sawzall. I dont know of a way to get it out without the key. IF you did have the key you put a paperclip in the tiny hole in the face near where you put the key and turn it back until the lock cylinder comes out.
Others might chime in on a way they have found without the key.
Phil
'70 Longhorn 421 700r4 tach 4 wheel disc hydroboost daily driver
'72 short super build
4wd '72 Suburban LT4 coming soon!!
s_nova69 is offline   Reply With Quote
Old 10-31-2012, 09:07 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Welcome to the board John.
Read this thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=462981
s_nova69, you should read it too, it will give you a better understanding of the procedure so you can pass the correct information on.
Let me know if you have any other questions...
LockDoc
Leon
