10-01-2012, 06:45 PM | #1 |
WTB 69 Rear spring hangers
Hey,
I am in need of 69 rear spring hangers. I have the front, but the rear's are year specific. They are shorter than 71-72. I think even the 70's are slightly different. If someone has these it would make my day! |
10-01-2012, 07:13 PM | #2 |
Re: WTB 69 Rear spring hangers
I have a set from a 69 gmc leaf spring rear. 45.00 shipped
10-01-2012, 07:14 PM | #3 |
Saweet! Do you have pictures?
10-01-2012, 07:51 PM | #4 |
I'll get you some tomorrow.
10-01-2012, 07:57 PM | #5 |
Thanks a bunch!
10-01-2012, 08:15 PM | #6 |
Make sure you say 4x4 also. Sorry the ones I sold you was wrong.
10-02-2012, 10:42 AM | #7 |
Good point thanks! And don't worry I'll finish cleaning the ones I bought from you and sell them on here. Someone will get a good set of rear spring hangers for 71-72.
10-02-2012, 10:43 AM | #8 |
If the 2wd is leaf springs....does it matter if its 2wd or 4wd? I do have a 4wd and looking to get this frame done.
10-02-2012, 11:49 AM | #9 |
2wd will be shorter. You could use them but you would need lift to take up slack from the shorter hangers. The 4wd hang down past the frame where a 2wd is closer to the frame.
10-02-2012, 12:18 PM | #10 |
Then I definitely need 4x4.. I may have to start a new thread to add that in the title.
10-02-2012, 06:27 PM | #11 |
Evening bump...anybody got any 4x4 rear leaf spring hangers for a 69
10-03-2012, 12:24 AM | #12 |
late night bump
10-03-2012, 03:03 PM | #13 |
mid day bump.. still looking for 1969 4x4 rear spring hangers. These can be off a suburban, or a K5 as well.
Thanks |
10-03-2012, 10:59 PM | #14 |
Nobody has these?
Posted via Mobile Device |
10-04-2012, 01:13 AM | #15 |
I had the same problem you did, 69 is one year only, 70 is one year only and 71 & 72 are the same. I have a 70 K5 and the frame is stamped in front of and behind the hanger to keep it from moving, see pic. As you can see the 71/72 hanger would not work for me. If your frame is flat where the hanger mounts you should consider using 71/72 hangers, much more solid. the holes are off but you can re-drill them to make it work. If your frame is like mine then you're screwed and will have to wait til someone comes along and can help. Unfortunately I became an expert in spring hangers (not by choice). Burb's, K5's and K10's all use the same hangers and 2wd and 4wd are different If your able to use 71/72 hangers by drilling new holes and you want to go that route let me know, I have a set that I bought before knowing what I know now about spring hangers.
10-04-2012, 09:05 AM | #16 |
Thanks Jdubs,
I learned the hard way as well. But I'm going to keep looking for 69 set. Someone has to have a set. Still looking |
10-04-2012, 09:36 AM | #17 | |
10-04-2012, 12:50 PM | #18 |
Bump to the top
10-04-2012, 04:14 PM | #19 |
afternoon bump
10-04-2012, 07:03 PM | #20 |
evening bump...69 4x4 rear spring hangers
10-05-2012, 01:11 AM | #21 |
Saw this tonight. Good deal and you lucked out, because they don't come around often.
http://67-72chevytrucks.com/vboard/s...d.php?t=546133 |
11-01-2012, 12:11 AM | #22 | |
11-01-2012, 04:25 AM | #23 |
Yeah I still have them I will pm you
