Electric Fuel Pump
I am just getting my motor ready to fire. I am running a 350 bored, cam, headers, intake etc. I am wondering what ratings I should get for an electric fuel pump? I am running a Holley street avenger 650. I am set to run 14 psi but not sure what flow rate I need?
What would you run?
Confidence is the feeling we have before we fully comprehend the situation |
Re: Electric Fuel Pump
I don't claim to be an expert, but that sounds like too much pressure to me. You might want to double check your numbers before deciding on a pump. I would normally think around 7 PSI.
Adam |
i'd run a good old reliable mechanical fuel pump as that setup there is no need or advantage in running an electric prone to problem and failure fuel pump
Quit if it's not FUN!!!
I agree with cdowns, above. That's way too much fuel pressure for a street Holley. Most Holleys will live well with 5-7 psi. A good mechanical pump will serve well for that. Plus, in my experience, most electric pump are just flat-out NOISY. But, It's your truck and the choice is up to you.
. I ran this pump on a 468 cu BBC and a 750 Holley and had zero problems: http://www.summitracing.com/parts/hl...7-11/overview/ . Carter makes an electric pump that will deliver about 6 psi. . http://www.summitracing.com/parts/crt-p4070/overview/ Last edited by TobyArnot; 11-01-2012 at 07:38 AM. |
#5 | |
honestly get a stock fuel pump, mount it on your motor and enjoy. for example, i had stock pump on my 750cfm, performer rpm intake, comp 280 cammed, headers, dart headed 350 motor, never had any problems. hope this helps.. |
5-7 psi is what you should be running. I suggest just using a mechanical pump, unless your engine is like mine and has no place for a mechanical. Edelbrock and Holley both sell performance electric fuel pumps, costly but good quality. I personally just purchased a off the shelf one at AutoZone, and haven't had any issue with it so far. Runs 5-7psi, fuel filter that mounts to it, and is internally regulates the pressure.
Joseph Joe's 69 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=543253 1969 GMC SWB-350 SBC 700R4 2013 Ram 2500 CC Laramie Longhorn Edition-6.7 PPEI EFI Live CSP5 5” ProFlo Exhaust |
5-7 psi. If you really have to run an electric, look at Carter pumps. They have some self regulating ones which will work very well for you. I had one on my Camaro for about 20 years! Not one single problem with it!!! ALWAYS run fuel filters before, and after electrics. A filter before keeps any trash from your tank from being circulated through the pump, and ruining it.
