Closed Thread
Old 11-01-2012, 04:02 PM   #5251
shawno72
C/10 junkie
shawno72's Avatar
Re: What did you do to your truck today!
Originally Posted by willys72fleetside View Post
Finally got the rest of my engine parts to get it back together
Looking really good!!
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline
Old 11-01-2012, 07:09 PM   #5252
mud.man.rj
mud.man.rj's Avatar
That s such a nice seat Vdog, really nice.
mud.man.rj is offline
Old 11-01-2012, 07:36 PM   #5253
VDOG
Grand PooBaa Member
VDOG's Avatar
LOL!! Thats "Its Randys" seat, I was just commenting on it. LOL
Now on the other hand, I touched up my grille. Now to polish it up.
VDOG is offline
Old 11-01-2012, 09:22 PM   #5254
mud.man.rj
mud.man.rj's Avatar
Haha, oh nice grill too Vdog...but the seat rocks.
Old 11-01-2012, 09:36 PM   #5255
ole dollor
ole dollor's Avatar
a little time and black paint makes a big difference on your grill.....good job...looks great.
and randy that is a real nice job on your seat to.....
ole dollor is offline
Old 11-01-2012, 10:01 PM   #5256
54belair
54belair's Avatar
Today, I finally took the time to actually put the cab on the rotissary. (Been sitting beside the rotissary for over a month--every morning I look and sure enough - no elves showed up over nite to put it On the rig.
Now I can quit working on the top side and flip it to finish up the bottom. I just doubled my work load----now I can work the chassis and the cab!!
1997 shortie stepside
1968 short stepside
1966 mustang
1966 chevelle ss
Dont always go the cheapest route--You can save yourself into the poorhouse!
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=489030
54belair is offline
Old 11-01-2012, 11:21 PM   #5257
Country_Boy_2007
Country_Boy_2007's Avatar
Lol seems like you have the same problem as i do, those damn elves keep skippin my shop too.
1987 Chevy 4x4, lifted 6 inches 35"BFG KM's My Baby
1988 Ford F250HD 5 sp 4x4 7.3L The Work Truck
1970 Chevy C30HD long WB Dulley, 4 sp 350...for now The Project
If you cant dazzle them with brilliance, baffle them with Bull$***
Country_Boy_2007 is offline
Old 11-01-2012, 11:56 PM   #5258
jd7
jd7's Avatar
I put in a new ignition switch, I picked up my grill from the polisher, [ full restoration including re-anodize ] bought a comp cam vac canister,also bought an msd ignition system.
jd7 is offline
Old 11-02-2012, 12:30 AM   #5259
ItsRandy
ItsRandy's Avatar
Originally Posted by VDOG View Post
Randy the seat and door panel look great. So my friend what do you really have left to do, your almost done right? Also I cleaned up the grille and im getting ready to repaint the black lines and lettering.
Still have to finish the bed (wood), spray the tail gate finish the rear wheel tubes and color sand the truck.
ItsRandy is offline
Old 11-02-2012, 12:40 PM   #5260
VDOG
Grand PooBaa Member
VDOG's Avatar
Oh you still have a lot. Holla if you need some help.
VDOG is offline
Old 11-02-2012, 12:52 PM   #5261
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Im just cleaning up around mine today..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline
Old 11-03-2012, 12:00 AM   #5262
jd7
jd7's Avatar
hope this works
jd7 is offline
Old 11-03-2012, 03:30 PM   #5263
nlped
nlped's Avatar
More than one day, but I finally got all the original suspension & brake stuff off and replaced it with all new or rebuilt pieces.
McGaughy 13" Disk Brake kits F&R, new stainless brake hardlines and softlines (Inlinetube.com), CPP 4 wheel disc M/C & P/V, '76 upper & lower control arms with Moog bushings & ball joints, '76 steering parts (all new Moog pieces), Ground Force 1" drop front drop coil springs.
Rear is a built '88 12 bolt with an Auburn diff, 3.42's, new bearing/seals etc, and machined axles (to fit the McGaughy brake rotor hat), ECE rear shock relocation kit (thanks CC69Rat), and CPP rear deluxe bent panhard bar and rear drop coils, Total drop is 3.5" in the front and 4" in the rear. I didn't want it to be crazy low because I'm gonna use it a good bit. The wheels are 1st Gen Boss 338's...Front's=18x8" with 255/50r18 Toyo ST's, Rear's=18x9.5" 295/45r18 Toyo ST's.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline
Old 11-03-2012, 10:28 PM   #5264
PAWS 72
PAWS 72's Avatar
Put gas in bessie,went to cruis inn and got my butt wet before i got home.
PAWS 72 is offline
Old 11-03-2012, 11:01 PM   #5265
69GWC
Installed a new turn signal switch and got my brake lights working again.
69GWC is offline
Old 11-04-2012, 02:34 AM   #5266
74baggedbug
Installed my new rear window , adds a lot of circulation to the cab when I remove the rear window
74baggedbug is offline
Old 11-04-2012, 08:21 AM   #5267
That is neat. I don't think I have ever seen a rear window setup like that.
Palf70Step is offline
Old 11-04-2012, 09:45 AM   #5268
Boog
laying low
Boog's Avatar
^^^^ Same here. Care to share some info on it?
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Boog is offline
Old 11-04-2012, 11:40 AM   #5269
74baggedbug
Me and another forum member had them made, this is the 1st one the company has ever made for our trucks , I need to talk to the owner on Monday and tell him what I think of it and the design. He may want to change a few things but that will be up to him. I didn't want a slider rear windshield nor would I hack up my truck to install a powers sliding glass like some old vehicles have .. I'm surprised of the response I've gotten so far about the window hopefully we will see more of them thanks
Old 11-04-2012, 12:17 PM   #5270
Hart_Rod
Hart_Rod's Avatar
That's pretty cool!
Hart_Rod is offline
Old 11-04-2012, 12:34 PM   #5271
Razor454
Razor454's Avatar
I cut out my old "heater" dash last night and I'm planning to media blast the modified AC dash today.
1967 SwB, 454 BB, 4L80E trans, 3.73 eaton posi
1997 C2500 Ext Cab 5.7 Liter
1955 3/4 ton 1st series w/ 235 straight six Sold it
Razor454 is offline
Old 11-04-2012, 01:43 PM   #5272
sduckworth13
sduckworth13's Avatar
Nice Job Mark
Scott
sduckworth13 is offline
Old 11-04-2012, 01:47 PM   #5273
ole dollor
ole dollor's Avatar
i also would like to know more on your back window....looks nice.
Old 11-05-2012, 04:11 AM   #5274
80sbaby 209
i built my passenger door panel today got a late start ill have the drivers done by next weekend http://67-72chevytrucks.com/vboard/a...1&d=1352102997
80sbaby 209 is offline
Old 11-05-2012, 04:14 AM   #5275
80sbaby 209
http://67-72chevytrucks.com/vboard/a...1&d=1352103233
Closed Thread
