Old 10-10-2012, 10:40 PM   #1
TxRat
TxRat's Avatar
project 66 beater
Well I finally bought a truck.
Its a rough 66 with 327 and lots of little issues that I didn't discover until I bought it. I plan on turning this into a true rain or shine daily driver.
It has a 327 with a 700r4 trans behind it. Its a big back window (custom cab?) factory A/C factory automatic.
I replaced the P/S pump and found the steering box flexing on the frame. I took it off today and found the frame cracked.
This may contribute to the wicked dead wobble the front end has..
I will add pics tomorrow as I ran out of light..
I feel like I'm posting all over the place but I will be updating this thread as my build thread.
My to list:
square up the front suspension
correct the down shift problem with the 700R4 (replacing the TV cable and bracket)
Repair cracked frame and add a Captain Fab steering box brace.
CPP Grand Slam Basic kit
fix a draw on the charging system
Replace passenger door
and, and, and....
TxRat is offline   Reply With Quote
Old 10-11-2012, 12:15 AM   #2
Narxoleptic Customs
Re: project 66 beater
Great stance!! It's great that it is a running driving rig. But please do not tear it all apart and take 3 yrs to get it going again...
Narxoleptic Customs is offline   Reply With Quote
Old 10-11-2012, 12:17 AM   #3
sandiego65
sandiego65's Avatar
Looks cool already
sandiego65 is offline   Reply With Quote
Old 10-11-2012, 12:24 AM   #4
TxRat
TxRat's Avatar
Its got horrible steering geometry, the front end shakes violently at times so I have to address that. The cracked frame around the steering box and the battery drain sill be the only two real things that will be addressed and it will be back on the road.
Old 10-11-2012, 07:10 PM   #5
TxRat
TxRat's Avatar
got the crack in the frame stitched up and metal finished, Waiting on my captain fab steering box bracket to come in..
Heres pics of the the spindle off as Im trying to figure out what I have so I can order drop kit..
Any help identifying would be great..
Old 10-24-2012, 09:13 AM   #6
duallyjams
duallyjams's Avatar
Here is a pic of the repro fan shroud and clutch fan
opening in the shroud is 19"
I'm running a 18" 7 blade fan
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 11-01-2012, 11:14 PM   #7
TxRat
TxRat's Avatar
Originally Posted by duallyjams View Post
here is a pic of the repro fan shroud and clutch fan
i'm running a 18" 7 blade fan
Attachment 1002996
thanks!!!
Old 11-01-2012, 11:23 PM   #8
TxRat
TxRat's Avatar
I finally got it back on the ground. 4/5 drop that's now done right. Now I'm going through all the wiring. Its a mess. Dual fans and elec fuel pump without relays. Someone used house wire to wire the truck, lots of cracks in the insulation.
That's not bubble gum welding at the front of the bracket. P/O added some extra hole for the P/S box.
Found a fleet bed for it
Old 11-01-2012, 11:29 PM   #9
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Coming along nicely.
That looks like a nice short fleet bed.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 11-02-2012, 10:28 AM   #10
TxRat
TxRat's Avatar
Thanks LostMy65.
Old 11-02-2012, 12:53 PM   #11
Low Elco
Cool ol' beater truck. I love me some cool ol' beater truck! Ya gonna blast and epoxy that bed?
Low Elco is offline   Reply With Quote
Old 11-02-2012, 02:54 PM   #12
TxRat
TxRat's Avatar
Thanks, I plan on Epoxying the whole truck eventually.
I picked these up from a guy south of San Antonio.
Old 11-02-2012, 05:09 PM   #13
Terry12
Curious, why you chose to swap the beds and go with a fleet side?
Terry12 is offline   Reply With Quote
Old 11-02-2012, 07:45 PM   #14
TxRat
TxRat's Avatar
I like fleet beds. Besides this will be a working truck so I wanted a little more bed...
Old 11-02-2012, 08:12 PM   #15
duallyjams
duallyjams's Avatar
Looking good.
James
IG duallyjams
Old 11-02-2012, 08:59 PM   #16
Shooters_7
Might want to check and fix some of the corrosion, especially since your down by the ocean. Typical issue as my truck has it too.
Conner
1965 Build: http://67-72chevytrucks.com/vboard/s...d.php?t=535078
Shooters_7 is offline   Reply With Quote
Old 11-02-2012, 09:14 PM   #17
TxRat
TxRat's Avatar
Ha well you're close shooter. That there is some good old gap jumping bubble gum welding at it finest. Somewhere in this truck life someone tried to weld that up and did a poop job of it.
It will be addressed eventually. Its on the LONG list..
Old 11-07-2012, 08:58 PM   #18
TxRat
TxRat's Avatar
I managed to to rewire my fans and put them on relays, They were wired straight to the fuse box before.
Now I have one that comes on with the key and the other comes on at 185*
here's the hillbilly wiring I pulled out that was running the fans.
Pulled these killer speakers out of the cab
took care of this really bad oil leak, Rear main and pan gasket
and did a little tuning on the engine, sounds better..
VVV click the picture below VVV
Old 11-08-2012, 06:47 PM   #19
TxRat
TxRat's Avatar
Ok worked a little more on the 66 today.
I started installing the Bowtie overdrive TV cable system.
Very nice setup. Got the bracket and cable installed
But as I was pulling the old spring and about the install the corrector spring this came out with the old spring. It appears to be something to do with the stopping the movement of the plunger. When I first started to replace the cable I noticed the plunger movement was very limited. Now without this piece in the spring there is a lot more plunger travel. I'm at a stand still until I figure out IF I need it or not..
Old 11-09-2012, 07:46 AM   #20
Low Elco
Call em! I did 3 times. I'm running the BTO spring and nothing else. Good progress!
Old 11-09-2012, 07:53 AM   #21
mark 66
Nice job on the wiring. definitely the right place to wire in the fan relays.did you use a probe in the radiator or use the sensor on the top of the thermostst.very clean.
mark 66 is offline   Reply With Quote
Old 11-09-2012, 07:57 PM   #22
TxRat
TxRat's Avatar
Thanks Mark. I ran a a 170*-185* sensor in the thermostat housing.
One fan runs with key on and the other comes on @ 185*
Old 11-09-2012, 11:58 PM   #23
Bomp
Bomp's Avatar
Great soundin'exhaust. I clicked. Will be back to click again.
Bomp is offline   Reply With Quote
Old 11-18-2012, 12:03 AM   #24
TxRat
TxRat's Avatar
small update,
More wiring work. Wired up the lock-up for the convertor
added a late model cruise control/brake light switch as my disengage for the convertor.
While finishing up the Bowtie Overdrive TV cable set up I found that the throttle linkage was hitting the TV bracket.
A little 1/4" cold rolled rod and this is what I got.
In the process of making the linkage I found the lever coming from the throttle was loose and not allowing the throttle to go W/O. A few turns on the pinch bolt has that taken care of. When I drove the truck for the first time it seemed to be a bit of a pig This was the reason..
I have purchased a 71/72 cable and pedal from a forum member here to install at a later date.
Tomorrow is the big day as I will be able to drive it and see if all my hard work is paying off..
Old 11-18-2012, 02:20 PM   #25
McMurphy
McMurphy's Avatar
Its a rough 66 with 327 and lots of little issues that I didn't discover until I bought it. ....
I started reading this thread on the first day you opened it, and this clearly has stuck in my head.
It makes me laugh a little as so simple a statement seems for a lot of us to turn into hundreds of man hours in labor, and hundreds to thousands of dollars.
I guess any collection of steel, rubber, glass and wires that have been on the road for 40, almost 50 years (probably 4 or 5 times the expected life span) it is to be expected.
The size of the "issues" and how we approach the resolution is as varied as the people that do these.
That is what makes this web site so awesome.
I wish I could meet each and every builder and their build here, that would be an interesting day indeed !!
Sorry to wax so philosophical on your build, but inspiration strikes us at the most odd of moments, and never in locations of our choosing, eh?
I wish you the best of luck on your truck, if you post it, you know I will read it !!
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
