Old 10-18-2003, 10:38 PM   #1
Scott Johnson
Junior Member
Scott Johnson's Avatar
Rotisserie restoration?
Have any of you ever done a rotisserie restoration on a Suburban? Thinking about building one to do my 72 Sub 4x4. Any pictures or advice would be greatly appreciated.
Scott
71 C10 Step Daily Driver
72 K10 Suburban Work in Progress
www.louisianaclassictruckclub.com
Scott Johnson is offline   Reply With Quote
Old 10-18-2003, 10:58 PM   #2
dinnut
dinnut's Avatar
what is a rotisserie restoration? where you put ur car on a thing and can turn in 360 degrees end over end?
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 10-18-2003, 11:16 PM   #3
krazy_texan
krazy_texan's Avatar
yep, that is what it is
i have seen some pretty huge rotisseseries to, my best friends dad has one that he used for his T6 texan airplane
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 10-19-2003, 12:44 AM   #4
crazy4chevs
crazy4chevs's Avatar
end over end WOW, I thought they rolled them sideways.
70 chev c10 swb fleet
72 grill, sb 400, 2/4 drop.
68 chev c10 swb fleet
Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C
Classic GM Truck Club of Washington
crazy4chevs is offline   Reply With Quote
Old 10-19-2003, 12:52 AM   #5
Scott Johnson
Junior Member
Have a pretty good idea on how to build the thing, going to buy some steel next week and get started. Just wanted to see if anyone else had built one, so I could possibly avoid mistakes.
Old 10-19-2003, 02:43 AM   #6
Canadian694x4
Born To Lose Club
Canadian694x4's Avatar
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
I know ronh72c10 built one to restore his 1/2 ton truck. He even has a site with a computer drawing of what the rotisserie looks like. It will at least give you some ideas.
http://www.vbrfarms.com/rhanson/roti...otisserie.html
Brian Smith - "Born To Lose"
1969 Chevrolet K10 LWB Fleetside - Proud Owner For 22 Yrs - 1 of 208 Built & Sold In Canada!- 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's.
1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 3 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds
2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 17 Yrs- 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's.
2008 Yamaha Raptor 700r - Proud Owner For 15 Yrs - ITP Mud Lites.
2015 John Deere 1025R - Proud Owner For 8 Yrs - 24HP Diesel/H120/54D/260B/SB1154.
Canadian694x4 is offline   Reply With Quote
Old 10-19-2003, 09:22 AM   #7
Blue Beard
Blue Beard's Avatar
Sure would like to find a good set of plans for building these units..............
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 10-19-2003, 03:01 PM   #8
Scott Johnson
Junior Member
Gives me some more ideas, we`ll see what happens.
Old 10-19-2003, 04:15 PM   #9
ronh72c10
I've built one but wouldn't build it the same way again, somebody separately emailed me about it and here's my response:
I've only had frames mounted on my rotisserie so far, there wasn't any way to adjust it's CG close enough to balance it so it would rotate easily. A complete body should be easier, the L adjusters may have to be lengthened vertically, but they're easy to make so I wouldn't worry if you had to remake them. Since the Stang is a unibody make sure that the body is solid before putting it on the rotisserie, brace the door openings especially, it would really suck to tweak the body. Another thing, I've currently got a stripped 72 Truck frame (400lbs???) on the rotisserie and that seems pretty heavy for it, the body will probably be heavier so don't skimp on the structure.
That said, a couple of things I would do differently on another rotisserie:
1. A positive latching mechanism, a screw clamping down on the pivot just doesn't hold it well enough.
2. The two vertical posts at the ends would be replaced by a single thicker post (3 to 4 inches)
3. I'd make the horizontal pivoting support a 3"x3" tube instead of a 2"x2" tube, I bent it once when I dropped one end 6"
4. Get good castors, nothing is more frustrating than trying to get them to pivot when you're moving the rotisserie and they don't.
A couple of sites worth looking at:
My design was based on the following:
http://www.mgbexperience.com/rotator/
there is a design on this site using engine stands, but I didn't like it
http://www.autorestorer.com/
this guy built a rotisserie to support his roadrunner body,
http://www.sandysgarage.com/current.html
this site points to a comercial company that makes the rotisserie design that I think works well and would be how I would build the next one,
http://www.accessiblesystems.com/
Ron
72 Chevy C10 (rust repaired, starting body work)
72 GMC 3/4ton 4x4
72 Chevy C20 Suburban
38 Ford Tudor Humpback Sedan (from the darkside)
67 Pontiac Parisienne
55 Studebaker Commander 2dr Hardtop (Starliner)
My Youtube channel with Video Updates!
ronh72c10 is offline   Reply With Quote
Old 10-19-2003, 06:46 PM   #10
Blue Beard
Blue Beard's Avatar
Ron,
Thanks for the info links, lot to take in on those sites.
1970 Chev CST
2003 Harley Fatboy
1956 Chev Bel Air
1978 Silverado
2005 Monte Carlo
Old 10-19-2003, 07:55 PM   #11
Truck Hippy
Truck Hippy's Avatar
What does one cost new? I am going to get one when I finish my garage. Wes
wesbaird@charter.net
Truck Hippy is offline   Reply With Quote
Old 10-19-2003, 08:46 PM   #12
Scott Johnson
Junior Member
I think the bottoms up lift looks good, and that is the way I am leaning toward building one. Does anyone know the approx. weight of a Suburban body stripped? This will make a difference in what material I use. The only real problem I am having is deciding how high to mount my pivot point. I want to make the upright solid and not adjustable, and have the place where it mounts to the body adjustable. I came up with 48 inches high, but I would hate to build the thing and not have enough clearance to rotate the truck. I know an adjustable upright would solve the problem, but I think the thing would be a lot more solid with a fixed upright. I am leaning towards building the actual stand out of 3x3 box 3/16 thick. the pipe up top that holds the spinning mechanism will be 2 1/2 inch pipe 3/16 thick. The part that spins and attaches to the body will be 2 1/2 inch box 3/16 thick. I think this will be heavy enough, what do any of you think?
Scott
Old 10-20-2003, 07:39 AM   #13
Scott Johnson
Junior Member
ttt
