Old 11-03-2012, 09:40 PM   #1
gringoloco
A guy with a truck
gringoloco's Avatar
Re: How to: Ruin a perfectly good C10
Minor progress today--started assembling the CaptainFab D52 rear disc brakes. QUALITY components. Putting them together was pretty straight-forward, so I'll save you guys the gory details.
Of note: I cut off the backing plate on the driver's side and found that it is not a whole lot easier than just pulling the axles--oh well, live and learn Also found my massive wheel cylinder leak that had everything inside the drum soaked; the brake shoes literally fell apart when I pulled the drum...
Before, carnage, and tear-down pics:
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 11-03-2012, 09:47 PM   #2
gringoloco
A guy with a truck
gringoloco's Avatar
Again, really nice stuff. Everything bolted right up, no problems. Nice to have a product that performs as advertised and not have to worry about having sent them out for powder before mock-up. I painted the rotors and calipers the same scheme as the front brakes--I think they turned out well. Part of me wants to paint the calipers red, but I think the subtle grey fits this truck better...
-Chris
Old 11-03-2012, 09:52 PM   #3
gringoloco
A guy with a truck
gringoloco's Avatar
Still have to re-flare the axle hard-lines to mate up with the Kore3 braided lines--if that doesn't work, I'll just bend up some new. I like the end result; looks almost factory
In final assembly, I did find that I will need longer wheel studs and that the pad slightly contacts the rotor hub when rolling. Studs are cheap and I should be able to modify the pad backing plate to clear...
-Chris
Old 12-27-2012, 10:48 PM   #4
HotRod C/10
HotRod C/10's Avatar
What rotors did you use on this setup?
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
