soft top anyone
anyone know of a good place to purchase a softop fpr 87 K5
thanks scott |
http://www.coloradok5.com/kaylinereview.shtml
http://www.coloradok5.com/can-backreview.shtml http://www.coloradok5.com/skyler.shtml
350 Crate 10 bolt 3.73 2.5 lift 32x11.50 1904 Edelbrock http://www.oplnk.net/~spirit/K5front.jpg |
#3 | |
Big Block Blazer
/IoWnZa
[1985 Chevrolet K5 Blazer][454BBC][TH400][NP241][Dana 44][GM 12 Bolt w/ Eaton LSD][Hedman HTC Hedders][Dual 2.5" Stainless Steel Exhaust][Hedman Turbo Muffler's][Dual Spal's 14" Electric Fan's][32x11.50R15 BF Goodrich All Terrain TA KO's on 15x8 Rallys] |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Kayline was bought out by Soft top Specialties, but it is the same top. CRRoy71 has a soft top on his.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
Yes, I do have the STC soft top and I highly recommend them. I have had zero problems with mine. The only thing wrong, is a snap broke off of the side. That was my fault trying to pull on it at an angle. Other than that, I absolutely love it. I can take it down in a couple of min. and put it back up in the same.
There has been a few times that I had it down, and run into some bad weather and had to pull over and put it back up. If it was still the hard top, it would be sitting on stands at the house and I would have gotten wet! I also took a bunch of pics of the install if anyone would like me to e-mail them to you.
Chris '92 ext. cab s/b 4.3L "Sparky" '04 crew cab 2500 4x4 6.0L |
Thanks,
about how much do they run? I would imagine that they install similar to a jeep softtop. You guys helped alot thanks scott |
thanks
Scott Daily Driver Was giving to me by old roomate on 10-10-03 Thanks Dan 1987 K5 Small Block 400 holley 690 TB 4" Lift 33's and MSD ingintion soon to come. Wheeler 1988 Toyota Pickup Ivan stewart Fiberglass Fender 3" suspension Lift 33" BF MT's Lincoln Locked oh-yeah V6 External roll cage and 350 soon to come |
