Old 11-03-2012, 09:47 PM   #976
gringoloco
A guy with a truck
gringoloco's Avatar
Re: How to: Ruin a perfectly good C10
Again, really nice stuff. Everything bolted right up, no problems. Nice to have a product that performs as advertised and not have to worry about having sent them out for powder before mock-up. I painted the rotors and calipers the same scheme as the front brakes--I think they turned out well. Part of me wants to paint the calipers red, but I think the subtle grey fits this truck better...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 11-03-2012, 09:52 PM   #977
gringoloco
A guy with a truck
gringoloco's Avatar
Still have to re-flare the axle hard-lines to mate up with the Kore3 braided lines--if that doesn't work, I'll just bend up some new. I like the end result; looks almost factory
In final assembly, I did find that I will need longer wheel studs and that the pad slightly contacts the rotor hub when rolling. Studs are cheap and I should be able to modify the pad backing plate to clear...
-Chris
Old 11-03-2012, 10:14 PM   #978
lolife99
67-72 parts collector,…
lolife99's Avatar
Great work as always!
Is there any braking advantage to placing the caliper on the front side of the axle vs the rear side?
I would also be interested in the "longer wheel stud" part number you use.
Keith
Convert to disc brakes.
Old 11-04-2012, 12:27 AM   #979
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks! From what I've read, there's no discernible advantage either way--it's just what looked right to me. I did have to swap the calipers to opposite sides to properly orient the bleeders. There are stud part numbers floating around here somewhere, I'll have to do a search. These would get me by, as they're engaging 5.5 threads, but I'd feel more comfortable with a few more turns...
-Chris
Old 11-04-2012, 01:13 AM   #980
gringoloco
A guy with a truck
gringoloco's Avatar
A little research found this:
Stock rear stud: Dorman 610-138
Knurl Diameter 0.535
Package Quantity 10
Quick-Start Nose No
Shoulder Length 0.3125
Stud Material Steel
Thread Handling Right Hand Thread
Thread Size 1/2-20
Under Head Length 1.53125
Wheel Stud Style Serrated Stud
Potential replacement: Dorman 610-258
Knurl Diameter 0.536
Package Quantity 10
Quick-Start Nose No
Shoulder Length 0.25
Stud Material Steel
Thread Size 1/2-20
Under Head Length 1.71875
So, approx 4 more threads engaged which should be 9.5-10, using the "engage the same depth as diameter" rule, on a 1/2-20 stud- this is just about perfect.
-Chris
Old 11-04-2012, 05:17 AM   #981
lolife99
lolife99's Avatar
Thanks for the Dorman parts numbers.
Keith
Old 11-04-2012, 10:10 AM   #982
gringoloco
A guy with a truck
gringoloco's Avatar
NP! FYI, I checked the application on those studs and its what GM used on the Cadillac rear discs in the late '70s, so I think we have a winner
-Chris
Old 11-04-2012, 10:45 AM   #983
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
nice work as always. I couldn't tell for sure from the pics...but it looked like there's no inner or outer parking brake. Are you running w/o, did I miss something, or do you have something else in mind?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 11-04-2012, 01:57 PM   #984
Portmod7
Portmod7's Avatar
Looking good, nice work!
Super Blue - 1968 C-10 Short Stepside
Fastburn 385, 4-Speed Sag. on the Column, Coleman 9" Floater w/Detroit TrueTrac
Portmod7 is offline   Reply With Quote
Old 11-04-2012, 06:57 PM   #985
gringoloco
A guy with a truck
gringoloco's Avatar
No parking brake for now. The brackets accept 76-78 Eldorado calipers if I decide I want one.
Thanks! Chipping away...
In related news, I picked up a 610-258 at the LAPS-- doesn't look like they will be long enough, so on to the next plan, whatever that is...
-Chris
Old 11-04-2012, 07:24 PM   #986
68GMCCustom
Just curious. There are trans tailshaft and rear axle pinion type p-brakes that attach to the d-shaft.
Kurt -
Old 11-04-2012, 08:54 PM   #987
gringoloco
A guy with a truck
gringoloco's Avatar
I've had that thought, too. Hard to find an affordable pinion option. Who makes those you posted? What's the cost like? I can upgrade to the Eldo calipers for a couple hun.
-Chris
Old 11-04-2012, 09:04 PM   #988
gringoloco
A guy with a truck
gringoloco's Avatar
Ok, studs. The stockers are too short for the discs, the other replacements aren't much longer, so the third option is a F*rd part.
Dorman 610-298
Type : Serrated Stud
Thread : 1/2-20
Knurl Dia. : .547"
Length : 2"
Shoulder Length : 11/16"
I grabbed one of each from the LAPS for comparison:
-Chris
Old 11-04-2012, 09:10 PM   #989
gringoloco
A guy with a truck
gringoloco's Avatar
Length comparisons. I will have to slightly enlarge the axle holes to fit the .547 knurl of the longer studs, but I can live with that. Also may have to use long lug nuts or trim the speed-start tips...
-Chris
Old 11-04-2012, 09:19 PM   #990
68GMCCustom
Couldn't say...just did a few keyword searches.
Seems the 9" has the most options. I'm guessing captainfab could come up with something for our 12 bolts tho!
Kurt -
Old 11-04-2012, 10:00 PM   #991
raull
raull's Avatar
nice job !!! i personally like the calipers on that gray on your truck !!!!!
check out my build thread
71 c/10 step side 5.3 twin turbo
http://67-72chevytrucks.com/vboard/s...d.php?t=485320
raul
raull is offline   Reply With Quote
Old 11-04-2012, 11:10 PM   #992
Bomp
Bomp's Avatar
Nice build man. I may be late but never to late to subscribe.
Bomp is offline   Reply With Quote
Old 11-04-2012, 11:32 PM   #993
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks! I'm pretty happy with the grey, but part of me wants to show off a little. Red calipers only look good clean, though, and this thing gets driven...
Thanks! Welcome aboard
-Chris
Old 11-18-2012, 09:19 PM   #994
gringoloco
A guy with a truck
gringoloco's Avatar
Okey-doke. Finally wrapped up the brake install. Got the '70 Corvette master cylinder and combo valve mounted. The new studs also worked out perfectly for the rear; I didn't even have to drill, they pressed right in and give 13-14 turns of the lugnut before they're snug.
Boring pic sorry, but after my wife helping bleed the lines and bedding-in the rear pads, this beast STOPS! Calling this part of the project done Next up, lower control arms and steering linkage...
-Chris
Old 11-18-2012, 09:30 PM   #995
raull
raull's Avatar
where's the pix of the master and valve ?
raul
Old 11-23-2012, 08:48 PM   #996
gringoloco
A guy with a truck
gringoloco's Avatar
Sorry I missed your comment--been doing the family thing and spending time chasing down a possible new project--I need a 67-72 that I can haul the family in
Shot some pics just for you So, after installing my expensive, custom 1" bore master cylinder and having basically no pedal feel and loooooong travel, combined with poor stopping, I swapped to a '70 Corvette power brakes 1.125" deep bore style I picked up at the LAPS. Painted 'er up with the same Eastwood grey I used on the calipers; it bolted right up to the booster and my existing lines screwed right in. Works like a charm--pedal feel returned and it locks 'em up no problem. The combination valve is a CPP unit that I picked up on eBay for cheap. All the lines screwed right into it as well, thanks to GM standardization.
Crappy, night-time, cell-phone pics- sorry, it doesn't like to focus at night...
-Chris
Old 11-24-2012, 12:31 AM   #997
raull
raull's Avatar
[QUOTE=gringoloco;5718943]Sorry I missed your comment--been doing the family thing and spending time chasing down a possible new project--I need a 67-72 that I can haul the family in
cool , so i take it we are looking for a sub then !!!!
raul
Old 11-24-2012, 10:07 AM   #998
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I vote for a blazer for the family project...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 11-24-2012, 11:23 AM   #999
gringoloco
A guy with a truck
gringoloco's Avatar
Well, you're both right, kinda. I started out looking for a Sub, since its the logical family hauler choice. I like the look of them slammed, but while looking around some, I showed a few to my wife, who made a face like she smelled something awful. When I showed her a Blazer, it was "ooh, that's nice". She also told me she knows how much I miss my old Blazer (I tell her so every time I come across a picture of it, or see a nice one at a show), so we're leaning more towards a Blazer at this point. I'd like to find a nice 2wd, but will settle for the right 4wd that I can later convert
More to come
-Chris
Old 11-24-2012, 12:37 PM   #1000
classicchev
classicchev's Avatar
Just cant get the Blazer out of the memory bank EY!!!!! I know of a couple that are decent.
67- 72 Parts collecter
classicchev is offline   Reply With Quote
