#1 | |
Re: 700r4
The Auxiliary valve body houses the Forward Clutch Accumulator. GM added the forward clutch accumulator in order to give a much nicer (smoother) engagement when placing the shift lever into drive, This accumulator cushions the apply of the forward clutches. In the earlier models......Some vehicles would bark the tires when dropped into gear and/or they would chew the splines off of the forward clutches over a period of time. This was REALLY a problem on TBI vehicles with the really high idle during cold starts & people not allowing the engine to idle down. Adding the accumulator fixed that issue......But created another one, People have a habit of not allowing the forwards to completely "latch" up before giving it gas.....Causing the forward clutches to eventually burn up. |
#2 | |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Re: 700r4
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
