Can't for the life of me figure out...
Why my Center Link is rubbing on my front cross member. Re-did the front end, 72 componets...Pitman arm hasn't moved, Idler arm was taken off but put back on. Center link isn't backwards, WTF! I've noticed a couple of other guys had this problem but I couldn't find the answer I was looking for. Center Link does not seem bent at all, everything looks right but obviously isn't. Just perplexed...
Senior Enthusiast
Re: Can't for the life of me figure out...
The problem may be the idler arm. Looking up the 1966 idler arm it appears to fit a variety of Chevy cars and trucks from 1961-1966. The 1972 idler arm seems to fit trucks from 1967-1982. If either the arm length or mounting angle is different, that may be causing your problem.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
60-66 Nut
Did you install power steering also? If so what box, and what pitman arm did you use. Is the idler arm the stock '66 piece? What year is the steering linkage. Is it original or '72 components?
#4 | |
![]() Quote:
![]() Last edited by luvbowties; 11-05-2012 at 07:58 AM. Reason: added info |
