8 Lug Disc Brake Conversion Kit
Does anyone know if this exists for an 8 lug (c20) - http://www.performanceonline.com/196...ION-KIT-5-LUG/
It looks like it's just a bracket that mounts to the existing knuckle/spindle. I found some place that can make them - http://www.blackbirdscustomtrucks.com/- but I would need to send my knuckle and such to them for them work off of (and then the cost is likely higher and I'd might as well just get donor parts from the junkyard (spindle, tie rods ball joints...etc form a 73-87) and do the swap that way). Thoughts or ideas (I've checked threads here and of course been googling away, so figured someone must have come across this if it exists). Last edited by BAMO; 05-08-2012 at 12:19 PM. |
Re: 8 Lug Disc Brake Conversion Kit
Theres one for sale on ebay right now. Selling as 3/4 -1 ton 8 lug disc kit for 63-72 c-20/c-30 truck. Currently at $100
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
That would do the trick as well...too bad he is way to far north of me to make life easy.
These dont pop up very often, I would keep my eyes on it.
I'm about to do the exact same thing to my 65 C20 this weekend.... assuming I can get the parts locally anyway.
In regards to the setup on ebay - will that work okay with the stock pitman arm and idler arm? I thought they needed to be changed over to the later model truck as well. Bill
65 C20 Fleetside longbed, 350, turbo 400, 8-lug disc brakes, power steering, air conditioning - Totaled by a guy running a red light. Pulling parts off the carcass for my next truck |
Hmmmm.... sounds like a question for CaptainFab. He seems to be the resident expert on these mods.
Better jump on that deal i paid well over $900.00 for my kit from cpp!! But seeing that is on ebay i bet it will go for about 400 to 500 before the auction is over.
MY 65 C20 BUILD http://67-72chevytrucks.com/vboard/s...d.php?t=483346 ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ |
#8 | |
What I was looking for was basically something that "mounts to your original spindle" which is what the POL kit does. I know the other 87 lug kits are there and I know I can get a donor 73-87 and pull things off. Just wondering anyone came across bolt on brackets. |
400-500 is still better than 900-1100
#10 | |
60-66 Nut
I wouldn't even bother messing around trying to put discs on drum spindles. I see absolutely nothing to gain when it is so easy to just switch to the '71-'87 C20 spindles, rotors, calipers, etc. The only thing I have not confirmed yet, is whether or not the '63-'66 C20 lower control arms will accept the '71-'87 C20 lower ball joints. I am pretty sure they will fit, but I just have not confirmed it.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 05-09-2012 at 01:12 AM. Reason: phat phingers |
I have been thinking about doing this on a 69 3/4 ton Chev. If you change to the 71 to87 3/4 ton balljoints then you ca use the spindle from 71 to 87. You will have to do somthing about the tierods,but if you use the relayrod and tierods from the donor vehicle all you need then is master cylinder and brake hoses. You can either reroute your front brake lines or leave them and get longer hoses. hope this helps.
#13 | |
And to that end...picked up spindles, rotors, upper/lower control arms for $120 off a 73-87, so guess no need to worry about a bracket anymore.
#15 |
I just used a donor and unbolted my 66 8 lug complete front suspension crossmember and all and rolled in one from an 82. Easy and cheap! all one shot. drill two extra holes and if i remeber right, elongate two holes.
#16 | |
60-66 Nut
The '71-'87 lower control arms will not bolt up to the '63-'66 C20 suspension crossmember. On the '63-'66 C20's the lower control arm shafts are flat, so there is no sadddle on the crossmember as there is on the '67 and up C20's. The '71-'87 lower control arm shafts are round and require the saddle on the crossmember. Before you get too carried away, check to see if the '71-'87 lower balljoints will fit the '63-'66 lower control arms. If not, you can either switch the control arm shafts, or the entire crossmember.
#17 | |
1964 1 Ton flatbed service truck (sold) 1964 C-10 panel (project complete frame up build) 1957 210 post pearl orange |
#18 |
60-66 Nut
Yes. But you will want to look for a '73-'86 C30 or '87-'91 R30 (R3500) with dual wheels, since your '64 is a dually. The front hubs, rotors and spindles are different than for a single wheel C30 or a C20.
#19 |
I have a complete change-over crossmember to covert that C-30 to discs and its all new. I bought brand new control arm from dorman-come with balljoints and shaft kits installed-about $125 each. Also has new hubs/rotors, calipers, pads, bearings, seals, tie rods, hoses,Monroe Magnum shocks. Only about 2000 miles on it all.
it's the 1976 chevy dually discs, with the JB 8 brake setup(largest GM made then) I am selling as a unit, ready to bolt it w/sway bar, the frame stiffener plates that are OEM, bolts, etc. PM me if anyone needs it- can be shipped truck freight. |
#20 |
thanks, for the info, so then i was off to Craigslist land and found one as you stated, i will pull it next week, i got it for $100.00 for everything, so i'm feeling pretty good so for around what i have in parts and the brackets i bought from you,i should have have P/S P/B with disks and be in at around $300.00 it pays to do research.
#21 |
Captianfab, is there any way to tell just which setup it is for the single wheel vs the dually for the later C30's? I have a full cross member off a later C30 for my 1964 C30 dually, how can I tell which later front I have? I'd just change the entire cross member, but the person that gave me the thing cut it off literally around the rear bolts to the A arms, and it ain't pretty, and isn't going to be workable to fit up.
#22 |
60-66 Nut
Do you have just the spindle and no hub and rotor?
#23 |
nope it will be complete with A arms , all the center link, etc. i'm getting the whole thing with steering box,
opps never mind you were not asking me ! my bad lol
