![]() Join Date: Jul 2001
Convert van tilt auto to floor shift truck tilt ?
I have not been able to find a floor shift tilt column with out spending vast amounts of green stuff. Is it possible to use a floor shift column bowl without the shifting arm, and mount it to an automatic truck tilt there by eliminating the shifting arm and giving the look of an original floor shift truck tilt? What about using the same procedure on a keyless van tilt from an early 70's van? Are the columns all the same between the truck and early vans? I know that the van tilt must be shortened for the shaft to fit. I have the possiblity on a early 70's van tilt (auto) for a good price and not having a lot of experience with tilt columns need a bit of knowledge and advice here. Any wiring problems I'm apt to run into? Thanks for any replies and help.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
anyone ?
Mike
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires |
CCRider
I don't think the "bowl" from a non-tilt column would fit, and would be a major pain to install. The simplest method would be to cut off the bump where the shifting arm attaches and fiberglass the hole shut...after a repaint, you would be the only one to know. Depending on what year van tilt you get, it could plug in or need an adapter. The color codes are the same on both, I just used well hidden butt connectors.
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
The tilt I have in mind is from a 77 Chevy auto column. It is still in a yard and they priced it to me at $65 and they pull it. The turn and tilt lever do not match our truck years. Are they a simple swap out item for correct tapered style? Also the 4-way hazard switch is fastened by a Phillips head screw. I can live with that after cleaning it up and painting the screw head. The NSS on the column is not needed for my floor shift application, jumper or cut and delete the un-needed wiring? Lots of questions I know but never having done this before don't want to buy a column and then not be able to use it. Again, thanks for the help.
Firefighter
Yes you can change the tilt and signal levers out with the correct style the tilt lever just screws in and the signal lever is held in place with a phillips head screw. As for the wiring you shouldn't have to remove anything for the saftey switch because the only things on the column plug are for the turn signals hazard lights, horn, and the light for the indicator and since you are going for the floor shift then you don't even have to hook it up. and GM makes an adapter for the flat to u-shaped plugs. It is GM part# 1894851. I hope this helps!!
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA ![]() ![]() |
