Old 11-05-2012, 08:14 PM   #1
Mstl67custom
73-87 motor mount on 67c20 frame misfit
I have a 67 c20 with a 73-87 c20 front crossmember the v8 motor perches from the 73-87 dont fit well on top of the frame. Anyone gone thru this before? Its look like the top of the 67 frame is wider than the newer one. The truck was originaly coming with a 6
Mstl67custom is offline   Reply With Quote
Old 11-05-2012, 08:27 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: 73-87 motor mount on 67c20 frame misfit
The FAQ Forum has a lot of informative threads on it. This one is located there and it may tell you what you need to know.
http://67-72chevytrucks.com/vboard/s...d.php?t=128765
LockDoc
Leon
Old 11-05-2012, 09:02 PM   #3
JohnT71
This is what we did, just cut square tubeing and spaced the top. It is a 86 front crossmember on a 68 frame with motor mounts from the 86
"There's a force in the universe that makes things happen; all you have to do is get in touch with it. Stop thinking, let things happen, and be the ball." -Ty Webb
JohnT71 is offline   Reply With Quote
Old 11-05-2012, 11:24 PM   #4
Mstl67custom
Ok thank a lot guys
