Re: Transmission service question/ pan
I put a drain plug in a 700R4 transmission in my Camaro 12 years ago. It came with a shift kit I had put in it. I have never had a leak since doing it. You do have to drop the pan, drill it, clean it real good. But once it is done, servicing the transmission is a breeze! Mine was a double threaded plug. In other words, the inside piece slipped through the drilled hole and screwed into the outside piece. The inner is hollow, call it the bung, so a bolt screwed into that, which is the drain plug. No welding at all, and never a leak. If it is done right they shouldn't leak.
2004 Chevy Suburban 1986 Chevy Camaro IROC-Z - LS1/T56 1990 GMC Suburban - The "TTurburban" |
| Bookmarks |
