Senior Moment
![]() Join Date: Mar 2002
Gas gauge wont hold still
My gas gauge needle moves back and forth from 3/4 to 1/4 while i'm driveing. I'm thinking sender unit ? anybody else have this problem? Who sells a good replacement?
Its driveing me nuts Thanks Steve 1970 CST Short Wide
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
Life is Good !
I had the same problum ! Never really figured out what it was !
'72 Chevy C10 4x4 shortbed "Project" '71 Chevy C10 2wd longbed "partsrunner" '91 Chevy Burb 4x4 "kidrunner" '14 Honda Accord Sport "commuter" |
I got a new sending unit from LMC.
It sounds like you may not be getting a good ground. |
Senior Moment
As I suspected. I'll be cheching for a good ground and look for a good replacement sender.
Unregistered User
![]() Join Date: Dec 2001
I have the same problem, but it only started after I replaced my instrument cluster bezel. I'm sure it's a ground issue, but I'm not sure where the cluster is supposed to be grounded to the dash.
Can somebody tell me where the ground is supposed to be connected? I don't know why I didn't note this when I pulled it out... ![]() Mike
71 SWB Stepside SB400/TH350 |
I had the same problem I think with my 71. The gas needle would flucuate back and forth when driving. I put in a different gas gauge and the problem went away
Black 72 Chevy
Grounding as others said. Check them.
72 Chevy, SWB, 350engine, TH400 |
Life is Good !
I had a ground issue with my dash also, mikej71 ! I just ran a wire from the back of the bezel and conected to the cab !
Hope this helps ! Landon
Try spinnin 4 rear tars
I just assumed it was from gas sloshing around in the tank...
When I turn a corner it moves up and down as the gas moves to one side or the other. It stays pretty still when going straight.
SWEET7T 1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB |
Unregistered User
Thanks Landon. I've tried attaching a wire from the metal housing to a screw that's in the bottom of my dash, but I guess i'll just try moving it around to different places.
Mike
