Old 11-05-2012, 06:00 PM   #1
gregbr
Senoir Member
gregbr's Avatar
Quick ratio steering box ???
Any one know of a 3 1/2 turns approx lock to lock, power steering gear box for a 4wd that uses the old style flare fittings? I have heard here that there are 2 models offered in 73-77 4wd trucks, 1 is a 3 1/2 trun & the other is 4 1/2 turn. I have the 4 1/2 turn already (stamped 7802644), would like more info on what truck to pull one from oe even a casting number. I recently picked up one from a 85 4wd (marked 7802644L) that is 3 1/2 turns, but it has different fittings on it than the one I have installed. Doesn't look like I can use the later model pressure hose since my pump mounts down low next to the balancer & the hose routes up the side of the pump, the later pump is mounted up high and the hose routes under the pump to the gear box.
Any ideas?? Thinking about swapping the guts of the 85 box into my 75 or so box to retain the flair fittings.
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4"
70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010
70 GMC Restoration Pictures
http://67-72chevytrucks.com/gallery/...00&ppuser=4424
gregbr is offline   Reply With Quote
Old 11-05-2012, 07:42 PM   #2
72 K20
72 K20's Avatar
Re: Quick ratio steering box ???
I believe there are adaptors to switch back and forth. Check with your auto parts store. Or,, have hoses made that have the correct ends.
72 K20 is offline   Reply With Quote
Old 11-06-2012, 09:32 PM   #3
gregbr
Senoir Member
gregbr's Avatar
Ok, WIll check around.
Old 11-06-2012, 09:47 PM   #4
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
76 and newer steering gears are 3 1/2 turns lock to lock. However they have a smaller input shaft, so you can't use the stock rag joint on your truck. You should be able to use the rag joint on the junk yard steering gear if it isn't destroyed. We have made and sell remanufactured quick ratio steering gears that have the larger input shaft that our trucks use. You can find them in our website: http://www.classicheartbeat.com/67-72_chassis_2.htm WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
