Old 11-06-2012, 10:26 PM   #1
Blue Heeler
Blue Heeler's Avatar
Front Disc brake and no booster
Was wondering if anyone is running front disc brakes and rear drum W/O booster and how does it work? if you have some pic's could you please post them? Thanks..
Blue Heeler is offline   Reply With Quote
Old 11-06-2012, 10:43 PM   #2
lil_sahara450r
Re: Front Disc brake and no booster
Now THAT is a booster!! LOL!!
lil_sahara450r is offline   Reply With Quote
Old 11-06-2012, 10:49 PM   #3
MikeS.
MikeS.'s Avatar
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
Old 11-06-2012, 10:50 PM   #4
MikeS.
MikeS.'s Avatar
Oh my! Those have been boosted. Me likes!!
Past Master
Old 11-06-2012, 11:26 PM   #5
chevy_mike
Never Ending Projects
chevy_mike's Avatar
I don't have any pics that can top that but I am running disc in the front, drums in the back with no booster and the original style MC. It works great, not overly firm but just right. I do have a manual trans which helps, as I can push the clutch in and am not having to overcome the torque converter.
Nice pic!
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 11-07-2012, 01:13 AM   #6
markeb01
Senior Enthusiast
markeb01's Avatar
These are the only photos I have back when I was running front disc brakes and no booster. I was running a 350/350 back then. After a couple of years my back couldn’t take the pressure any longer and I had to install a booster. Manual brakes are fine for a regular healthy person, but not so hot for someone with missing spinal discs.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 11-07-2012, 10:53 AM   #7
Blue Heeler
would i have to run the prop valve?
Old 11-07-2012, 11:08 AM   #8
glos55
glos55's Avatar
The prop valve reduces pressure to the rear brakes, which require less force than the fronts. Which will keep back brakes from locking up. I believe you can run without one....but I would want some type of metering valve to keep things equal.
LIFE IS SHORT HAVE FUN
glos55 is offline   Reply With Quote
Old 11-07-2012, 11:43 AM   #9
1963c-10
1963c-10's Avatar
Im fixing to run this set up on my 63. Disc up front non-booster and drum rear. Im running a pretty radical cam in my 427 BBC and didnt want any vacuum issues. Dont have p/s or i would have gone w/a hydrobooster. I do have the prop valve assembly though to help w/the rear brakes.
1964 Short bed trailer
Old 11-07-2012, 05:28 PM   #10
Blue Heeler
I would like to see pic's of your set-up if possible. thanks
Old 11-07-2012, 05:42 PM   #11
1963c-10
1963c-10's Avatar
No prob. I have everything at home in the boxes. I can get some pics tonight.
Old 11-07-2012, 07:17 PM   #12
markeb01
Senior Enthusiast
markeb01's Avatar
I installed the factory 1975 prop valve on mine ever since the front disc brakes were added. I mounted it below the engine on the front crossmember to keep the area near the booster clear. Here's a rather ugly picture that shows the location below the left engine mount:
Old 11-08-2012, 12:56 AM   #13
Blue Heeler
So yer not running a booster right? i checked the booster i have and it measured 17" with master cylinder which will hit the alternator.
