10-21-2012, 04:41 PM | #1 |
front axle lock??
got my 96 k1500 stuck bad today pss. front wheel fell into a ditch deep enogh the frame bottomed out. drivers rear tire didnt have much weight pushing down. so heres my question. while trying to back out of this mess, i noticed both rear tires spun, as well as the pass. front, but drivers front didnt, seems i would have got out a hell of alot easier if it did. i thought the front diff. was locked when in 4wd, what gives? is it that the pass. front was spinning so easily that it got all the power?
10-21-2012, 04:51 PM | #2 |
20' Daredevil (Ret)
Re: front axle lock??
Nope, the front diff is open (from the factory). Serious off-roaders often install lockers up front.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
10-21-2012, 04:55 PM | #3 |
thats what i thought but the owners manual says not to use 4wd on dry pavement (thinking because its locked), i messed up once and did it, could tell the tires were scubbing hard on turns. any ideas?
10-21-2012, 05:03 PM | #4 |
When turning sharp in 4wd the front and rear driveshafts try to turn at different speeds, causing the tires to chirp.
10-21-2012, 05:06 PM | #5 |
DOH!!! That makes sense. Guess I'll have to look into a front locker, aint going thru that ordeal again. Thanks for the fast replies, you guys are great.
10-21-2012, 05:08 PM | #6 |
20' Daredevil (Ret)
What 76k10 said. When turning, notice the front tires travel farther than the rears. This is easy to see on dirt, mud, or snow -- the front tire tracks take a longer (outside) path compared to the rear tire tracks. Your manual is right, you should only engage 4WD when you're on a slick enough surface to allow the tires to slip instead of binding the drivetrain.
10-21-2012, 05:13 PM | #7 |
A locker in the front probably wouldn't have gotten your out of that situation. If your truck is laying any significant weight on the frame or axles, you're stuck. A winch or a buddy with another truck is your best chance of getting out.
10-21-2012, 05:19 PM | #8 |
unfortunatly all i had was a shovel but i made it thank god
10-22-2012, 12:53 AM | #9 |
if its a 96 1/2 ton with the stock 8.25 ifc, your out of luck. no one makes lockers for 88-98 1500s. best you can do is lock-up the rear & go 3 wheeling
10-24-2012, 07:51 PM | #10 | |
You really don't want a "locker" (like a Detroit locker) in the front. They are harsh enough in the back, and very un-predictable in the front. You are really better off with a clutch-type "posi-traction" unit. They clutches slip enough for non-binding driving and much more "normal" steering.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
10-24-2012, 08:19 PM | #11 |
20' Daredevil (Ret)
^^ Exactly... my "serious off-roaders" above maybe should have been "hardcore off-roaders". I was thinking rock crawlers & air lockers.
10-25-2012, 04:31 AM | #12 |
If your going to off road it a lot i would do a solid axle swap on it.
10-28-2012, 01:13 AM | #13 | |
11-05-2012, 09:30 AM | #14 |
The only thing a locker does for me is let me get stuck even worse.
11-05-2012, 11:29 AM | #15 |
20' Daredevil (Ret)
The trick is to go until you are stuck.... then engage the locker and extricate yourself.
11-05-2012, 07:30 PM | #16 |
I use a detroit Tru-trac in the front, it acts as an open diff in casual 4 wheelin, such as on roads with snow and ice. Still gives you control under throttle. But if you bind the front end or apply the brake, as in a brake torque, you can lock the front end, works great.
Better then a posi/clutch type diffy, because even with a posi in the situation you described, both wheels probably wouldn't have turned. Mechanical locks are for sure the best in a truck.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205 1971 GMC 3/4 Ton 4X4 |
11-06-2012, 03:05 AM | #17 | |
his rear axle |
11-07-2012, 12:31 AM | #18 |
Ahh yes mine is a D60, I didn't realize they don't make them for most diffies.
11-07-2012, 02:15 AM | #19 |
they make 'em for pretty much any diff, except the gm 8.25 ifc. my d.driver is a 90 stepside 1/2 ton,same axles, have looked EVERY where, no luck. it's too lite duty, put a detroit in the rear & called it done. put a detroit in my crew, a detroit in my 71 jimmy, one in my 76 k5, another in my 78 3/4 ton- even had one in my 2wd 71 longhorn. price, durability, simplicity, their pretty tough to beat
