Old 11-07-2012, 11:34 AM   #126
67cheby
67cheby
67cheby's Avatar
Re: 1968
your frame progress is looking great !
67cheby is offline   Reply With Quote
Old 11-07-2012, 02:14 PM   #127
Xeen
Xeen's Avatar
Re: 1968
Looking at the 67-68 grill you just got does it look like you can piece the two together to make one good one?
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 11-07-2012, 08:08 PM   #128
gdavis
gdavis's Avatar
Re: 1968
I have a68 grill and a 69 grillI will be leaving them alone.what i will be making into one is the core supportI will be using the 69 grill with the 69 hoodwith 70 fenders
gdavis is offline   Reply With Quote
Old 11-07-2012, 08:13 PM   #129
gdavis
gdavis's Avatar
Re: 1968
Today, I wired wheeled the right front fender. I found a small hole in the front and rear of the fender and a little repair inside of the fender and that was all what is wrong. a solid fender from a 70 GMC 3/4 ton.
Old 11-07-2012, 08:15 PM   #130
gdavis
gdavis's Avatar
Re: 1968
Also installed the rebuilt drive shaft. What I mean by rebuilt is the u joints.
Old 11-07-2012, 08:30 PM   #131
Xeen
Xeen's Avatar
Re: 1968
The drive shaft looks good.
Those are some pretty nice fenders.
Old 11-08-2012, 10:05 PM   #132
gdavis
gdavis's Avatar
Re: 1968
Well today I welded some on my fender in the inside I still have some more to weld. I primed it already so it would noy rust here in Fl.
Old 11-08-2012, 10:11 PM   #133
gdavis
gdavis's Avatar
Re: 1968
Today I got a new V8 should and top supports for the radiator. I will stach them away for the future.
I also bought a rolling chassic 1972 with disk brakesLong wheel base for 200.00 5 lug wheels so it looks like i will be installing front disk on my truck before I wanted to.I could not pass that up. 2 hoods and another core support. three core supports to make one good one.
Old 11-08-2012, 10:14 PM   #134
gdavis
gdavis's Avatar
Re: 1968
I also primed both fenders I still need to find a inter fender for the passager side
Old 11-09-2012, 12:42 AM   #135
jonny..2008
Re: 1968
nice progress as usual.
great buy on the spares this week too.
i found here on c/l a set of sheet metal and cab/bed minus fenders for 300. but im not in the market for sheet metal.............
i love every machine. even the ones i hate.
Current project (1959) fifty niner gmc fleetside:
http://67-72chevytrucks.com/vboard/s...70#post6514670
MY daily driver truck thread : http://67-72chevytrucks.com/vboard/s...d.php?t=544460
jonny..2008 is offline   Reply With Quote
Old 11-09-2012, 01:40 AM   #136
Xeen
Xeen's Avatar
Re: 1968
Sounds like you are getting quite a collection of parts built up, they will undoubtedly come in handy.
Old 11-09-2012, 10:04 PM   #137
gdavis
gdavis's Avatar
Re: 1968
When I think I have all my parts cleaned or painted, I turn around and I find another parts that I missed. So today I sanded and painted the over flow bottle craddle. I also brought a six blade flex fan. I will put it up, where I don't know. I am starving for room.
Old 11-11-2012, 09:13 PM   #138
gdavis
gdavis's Avatar
Re: 1968
Made a different move. Not going to use the 69 grill and hood. I just did not like the way it looked. I am sure it would work, but my truck is a 68. SO I found a 68 with good parts and guess what It is mine. Got another cab today. It has the same damage but it has a good kick panels and the roof is in great shape. so, I scrape the 69 cab and started again. It is only time and I can get this one done a lot sooner. and less work and money.
Old 11-11-2012, 09:20 PM   #139
gdavis
gdavis's Avatar
Re: 1968
Also, I cleaned up more parts Saturday. My wife said that i can't keep buying old truck parts. That I have to make a stand or draw a line in the sand. She just don't understand my thoughts of madness. But, it will be clear to her one day.
Old 11-11-2012, 11:02 PM   #140
Bomp
Bomp's Avatar
Re: 1968
I hear ya brother. My wife don't understand either. Try explaining why there are Camaros hangin'. She says I is a crazy
Great job on all the clean parts!
Bomp is offline   Reply With Quote
Old 11-12-2012, 08:08 PM   #141
gdavis
gdavis's Avatar
Re: 1968
Today, I cleaned up the new cab. Getting it ready for sand blasting. Installed new dash so it could be blasted at the same time. Some one before me cut the radio hole and it needed to be fixed.
Old 11-12-2012, 08:12 PM   #142
gdavis
gdavis's Avatar
Re: 1968
This is the damage I have to fix on the new cab. The old cab had the same minus the roof and kick panels and pillar pass side
Old 11-12-2012, 08:16 PM   #143
gdavis
gdavis's Avatar
Re: 1968
more of the same damage
Old 11-12-2012, 08:17 PM   #144
gdavis
gdavis's Avatar
Re: 1968
pics
Old 11-12-2012, 11:54 PM   #145
Xeen
Xeen's Avatar
Re: 1968
Holy smokes that cab is in really bad shape, I dont really see how its in any better shape than the other one, but then im not there to look over every square inch of both cabs like you are and I cant see what you are seeing.
Then again you should have seen my original cab it was truly beyond saving, it makes yours look like a diamond haha
Old 11-13-2012, 10:00 PM   #146
gdavis
gdavis's Avatar
Re: 1968
Well, the roof is in good shape and the fire wall is in good shape, and the rain gutters are also in good shape. the rest of the damage is the same as my first cab. But give me a little time and it will look good.
Old 11-13-2012, 10:03 PM   #147
gdavis
gdavis's Avatar
Re: 1968
Today, I cut panels out of my old donor cab. and did a little more cleaning the new cab.
Old 11-15-2012, 10:01 PM   #148
gdavis
gdavis's Avatar
Re: 1968
Today, I welded and grind and welded and grind. A place needed some work above the wind shield and 6 inches in length. But it turned out real nice. Now I have to do the other side about 2 inches. Anyway I got the whole winter to do this cab. It was cool here and a little mist in the air. But weather is good working weather here in Florida. No more heat till summer.
Old 11-16-2012, 11:16 PM   #149
gdavis
gdavis's Avatar
Re: 1968
Today, I finished welding in the dash. Worked on the bad spots above the wind shield. It will take a few more tries to get it smooth. I was going to post pictures of the work above the wind shield but was not proud of the work. their are 3 groves above the wind shield and having trouble with them.
Also glassed the inter fender and finshed cutting out the new patches for the floor. I will weld them in tomorrow.
Old 11-17-2012, 12:00 AM   #150
Bomp
Bomp's Avatar
Re: 1968
I thought I had my hands full on cab work. You are a machine! I look away for a few days and Zowie....... You dang near have half the parts cleaned, painted and ready for install. Can't wait to see you tackle the cab.
