Old 11-04-2012, 01:11 PM   #1001
Ford Assassin
Ford Assassin's Avatar
Re: my 80 build
Still, any street driven daily driver truck in the 12's is pretty quick. 99% on the road wouldn't hold a candle against you.
I finally got my RevMax billet 9.5" 3600 (actual stall) installed. Now I need to address.my serious traction issues. Next I'll be ditching the crap Gov-Bomb with a Eaton TrueTrac and prob a set of CalTracs bars.
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 11-06-2012, 11:57 AM   #1002
truckzilla
truckzilla's Avatar
Re: my 80 build
I have to agree Aaron! Awesome results!
truckzilla is offline   Reply With Quote
Old 11-07-2012, 08:48 PM   #1003
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: my 80 build
thanks guys, I barley got pulled by my buddies full bolt on 5th gen ss on the high way
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 11-07-2012, 10:40 PM   #1004
flamingbig10
6.0 powered square
Re: my 80 build
Aaron
Old 11-08-2012, 01:12 AM   #1005
3r!c84
Badass
3r!c84's Avatar
Re: my 80 build
love this pic !
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 11-08-2012, 01:46 AM   #1006
Ford Assassin
Re: my 80 build
The next time you go on regular street tires, drive around the water box and just do a little dry hop instead of a burnout. The rubber compound in regular street tires get greasy and oily when they get hot vs drag slicks and DR's compound get stickier (to a point) when they get hot.
Prob will pickup another tenth in your 60ft on regular tires just avoiding the box and doing a dry hop.
Cable
Old 11-08-2012, 02:17 AM   #1007
flamingbig10
6.0 powered square
Re: my 80 build
that's what I usually do is a dry light spin, but I couldn't help my self kept doing john force burnouts lol
Aaron
Old 11-12-2012, 12:20 AM   #1008
flamingbig10
6.0 powered square
Re: my 80 build
These runs were baby it holding second gear off the line
Aaron
Old 11-22-2012, 08:59 PM   #1009
flamingbig10
6.0 powered square
Re: my 80 build
Aaron
Old 12-01-2012, 08:47 PM   #1010
flamingbig10
6.0 powered square
Re: my 80 build
got the nittos installed ran a 8.13 in the 1/8
Aaron
Old 12-03-2012, 05:34 PM   #1011
truckzilla
truckzilla's Avatar
Re: my 80 build
That's wicked hot Aaron! Out of curiosity, what was the cam that you went with?
Old 12-03-2012, 09:18 PM   #1012
flamingbig10
6.0 powered square
Re: my 80 build
texas speed 228r
Aaron
Old 12-17-2012, 01:08 AM   #1013
flamingbig10
6.0 powered square
Re: my 80 build
a little better at the track 8.07 with a 1.84, tried to run better so took the tailgate off and speaker box, it was much cooler out, then the track wouldn't hold best was a 8.14 with a 1.97 60 foot wheel hopped really bad at least 30 ft
Aaron
Old 12-22-2012, 12:58 PM   #1014
flamingbig10
6.0 powered square
Re: my 80 build
Aaron
Old 12-22-2012, 01:59 PM   #1015
3r!c84
Badass
3r!c84's Avatar
Re: my 80 build
Uh oh what happened
-00 Saturn 5spd
1/4:13:90
Old 12-22-2012, 02:29 PM   #1016
baclay9
Re: my 80 build
Looks like mine!
baclay9 is offline   Reply With Quote
Old 12-22-2012, 03:28 PM   #1017
flamingbig10
6.0 powered square
Re: my 80 build
I'm not really for sure, i'm going with some ccp tubular control arms
Aaron
Old 12-22-2012, 06:03 PM   #1018
truckzilla
truckzilla's Avatar
Re: my 80 build
Thanks for the info on the Texas Speed cam.
Are you going to go with some coil overs or what inside those tubular control arms?
My POS is still at a stand still which is why I haven't started a build thread yet! The follies of having to do it at a buddies house only on Sundays for half a day at a time!
Old 12-22-2012, 06:57 PM   #1019
flamingbig10
6.0 powered square
Re: my 80 build
no problem, just the cut coils, you'll get there
Aaron
Old 12-23-2012, 03:35 PM   #1020
flamingbig10
6.0 powered square
Re: my 80 build
ordered the control arms should be here in a couple weeks
Aaron
Old 12-23-2012, 07:42 PM   #1021
flamingbig10
6.0 powered square
Re: my 80 build
Aaron
Old 12-31-2012, 12:21 AM   #1022
flamingbig10
6.0 powered square
Re: my 80 build
I put the stock control arms back on got a junk yard control arm left the sway bar off cut a 1.77 60ft and 8.005 was my best time
Aaron
Old 12-31-2012, 12:23 AM   #1023
Ford Assassin
Re: my 80 build
Any 60ft less than 1.8 on a stock suspenson style truck is damn quick outta the hole.
No CalTracs yet, right?
Cable
Old 12-31-2012, 12:31 AM   #1024
flamingbig10
6.0 powered square
Re: my 80 build
nope, just a bunch of big guys putting weight on my truck when I launched
Aaron
Old 12-31-2012, 12:38 AM   #1025
mooseknuckles
mooseknuckles's Avatar
Re: my 80 build
keep choppin away at that 60' time and you'll easily be in the 7's.....you're runnin 3:73"s right?.....try some 4:10"s then if traction/hopping becomes an issue, soften up those rear springs....
mooseknuckles is offline   Reply With Quote
