#26 | |
Re: SquareBore to Spreadbore Adaptor Plate! (Is it Necessary?)
I've had the adapters and they work ok. I never noticed a crack, but it did develop a small vacuum leak on the manifold side after awhile. I got a deal on an intake and never looked back. One thing I can highly recommend is a heat insulator gasket with an Edelbrock carb. You'll be happy you did in the summer months.
BTW, the Edelbrock intake you would want would be pn 2161. I got mine off ebay for $50... It's for the peanut ports that I assume you have. Quote:
1982 C-20, 454, TH-400, PS, A/C, 71,000 miles 1978 C-20, 350, TH-400, PS, Non-A/C, 112,000 miles If it ain't broke, there is still probably room for improvement. ![]() Speed costs money, how fast do you want to go? |
#27 | |
A square bore will not bolt on a Q-Jet intake. You must use adapter Posted via Mobile Device |
