Old 11-09-2012, 08:02 PM   #1
cam-camaro
Just double checking before I go any further.
I have an 85 chevy 305. The oil pressure sending unit should be right behind the distributor right? I'm in the process of rebuilding and just want to make sure I get this thing as close to right as possible the first go 'round. I checked the forums here and most info. I found said it was behind the distributor, on the drivers side. The block I have has no current sender on it, and there is a filler plug in that location(machine shop filled it in). Does anyone have any pictures showing exactly where the unit should go? Also, does this motor need a knock sensor? And where does the knock sensor go?
cam-camaro is offline   Reply With Quote
Old 11-09-2012, 08:09 PM   #2
frog210
Re: Just double checking before I go any further.
my 305 has it behind the distributor
San Antonio, TEXAS
-Frog
-I'm a valet and well I've driven BMWs, Mercedes, Porsche,Bentlys, fiats, Hondas, etc and well even do I like a few features, I love my shortbed, it dosent bore me out, just press on the gas and you'll remember why you love it.
frog210 is offline   Reply With Quote
Old 11-09-2012, 08:14 PM   #3
cam-camaro
Thanks, I appreciate it. I'm just a little worried about the exact location, but I guess theres only one spot where it would fit.
Old 11-09-2012, 08:43 PM   #4
ont_guy_38
ont_guy_38's Avatar
It goes right there
1985 C10
2004 Avalanche
ont_guy_38 is offline   Reply With Quote
Old 11-09-2012, 10:24 PM   #5
cam-camaro
Thanks I really appreciate it.
