#501 |
Re: 68' Chevy c10
Lower half of something..... Sure hope that's not on a tittie then!
![]() Making a grommet for your column??
'77 K30 3+3 - "The Crummy" http://67-72chevytrucks.com/vboard/s...d.php?t=640134 '67 C10 L/SWB - Soon to be daily driver! http://67-72chevytrucks.com/vboard/s...d.php?t=471776 ![]() |
#502 |
![]() Join Date: Oct 2010
Re: 68' Chevy c10
Nope Nuthin like that. lol, It's actually a wheel bearing cap for a jeep cj. I'm making a shifter knob, and that will be the lower part of it. I searched thru tons of different things to use as a shift knob, but couldnt find anything I liked. so I figured I would just make one. we'll see how that turns out.lol
John Mild Custom 68' Work Truck Build Facebook LoL 1977 Trans Am (Project) 1965 Chevelle (Project) |
#503 | |
Re: 68' Chevy c10
http://www.ebay.com/itm/GUINNESS-POR...item4abd246186
94 k2500 EXCab Long Bed 350ci New Toy 95 K2500 Suburban New PlowTruck 454ci Support our Troops @ http://anyairman.com http://www.woundedwarriorproject.org/ |
#504 |
Re: 68' Chevy c10
Never been good at riddles, but the tittie thing was funny!
#505 | |
Re: 68' Chevy c10
yes sir.lol Not alot done on the truck over the past few days. except work on the back gauge tin, cut out for the tach, and painted inside gloss white. also cut out for tach on the front tin. working on a mounting for the tach. I want it mounted to the back tin like the other gauges. I have all the led,s for the cluster, and my matching ignition/door locks showed up Fri ! will try to have pics of progress posted later today.
#506 |
Re: 68' Chevy c10
Looking great John
project: "my happy mess" |
#507 |
Re: 68' Chevy c10
#508 | |
Re: 68' Chevy c10
Thanks Man !
Heres a few pics ! Cut hole for tach. in back tin. Painted gloss white. Mounted original tach trim ring to the front gauge tin with panel bond adhesive. Set up overnight and this will be solid. Got tired of it taking two hands to start, and my new matching set of locks showed up. so I installed the ignition. ![]()
#509 |
Re: 68' Chevy c10
Still working on gauge tins. I'll have some pics up in a while. 32 degrees in the shop this morning, brrrrrrrrr !
#510 |
Re: 68' Chevy c10
Really cool! Can't wait to see how that tach looks in there.
#511 | |
Re: 68' Chevy c10
#512 | |
Re: 68' Chevy c10
Yep, thats all I've been doing on the truck is the gauges..... still.......,but I'm finally done with getting everything mocked up. I still have to polish the lens, and repaint the gauge tin face.
I ordered a new printed circuit for my gauges. I never had any problems with it, but it didnt look too good, and would have to modify it to clear the tach anyway. Heres some pics. ![]()
#513 |
Re: 68' Chevy c10
OOOOwwwwweeeee, purdy! That's gonna look good in the truck.
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
#514 |
Good job man! It's a gem!
#515 |
Re: 68' Chevy c10
Looking good!
#516 |
Re: 68' Chevy c10
Nice work dude! Can't wait to see the install. Thanks for the call today. I ditched work and spent the day in the shop. I'd enjoy talking for a few to get your take on the prep work I'm doing!
#517 |
Re: 68' Chevy c10
Do you think you will get it painted before the snow flies or you waiting till spring?
#518 | |||
Re: 68' Chevy c10
Thank you ! Thanks litew8 ! Quote:
heres the last pics of the gauges until they are mounted in the dash. ![]()
#519 |
Re: 68' Chevy c10
The hard work paid off! Well done!
Adam My 1967 C10 - Turbo 250 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=485843 (608) 214-8706 |
#520 |
Re: 68' Chevy c10
Nothing like a dash full of gauges Verrrry sharp
#521 |
Re: 68' Chevy c10
Muy buen trabajo! Te felicito!
#522 |
Re: 68' Chevy c10
Thanks Adam ! Now I just need to sand, and clear again. polish the lens, and paint a black spot to hide the center of the tach. and replace the tach face.
Thanks Frankie ! I like how the fitment of everything turned out. muchas gracias ! emilio
#523 |
Re: 68' Chevy c10
If your taking the tach apart, rather than paint a dot on the glass, you might epoxy a black plastic dot on needle to cover the mechanism
#524 |
Re: 68' Chevy c10
Thats a good idea Adam. maybe I could use a button, and just fill the holes, and make it flat on the bottom...... hmmmm.
#525 |
Re: 68' Chevy c10
Not sure how an electronic tacho really works, but I dunno about adding weight to the movement?? Seems to me it might doink the calibration and / or make it a little "bouncy"?? Not sure, just thinking here! That needle can't be real heavy to begin with. A button or similar could double the weight?
Tags |
68 chevy, c10 2wd fleetside |
