Old 11-10-2012, 07:06 PM   #1
c10boob
c10boob's Avatar
Front Suspension Crossmember Removal
I have unbolted everything for the upper part of my front suspension (side bolts to the crossmember, upper ball joint, etc.) and there is absolutely nothing holding the crossmember to the frame - yet it still won't budge.
I've hammered it, chiseled it, soaked it in WD-40, tried to fit a puller on it. Nothing works.
Any ideas on how to remove this thing?
c10boob is offline   Reply With Quote
Old 11-10-2012, 07:25 PM   #2
vidman
vidman's Avatar
Re: Front Suspension Crossmember Removal
Did you get the 6 bolts inside on the bottom of the frame rails... there is a total of 7 bolts on each side
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline   Reply With Quote
Old 11-10-2012, 07:28 PM   #3
c10boob
c10boob's Avatar
No, I don't need the entire assembly out, just the crossmember circled in red.
Old 11-10-2012, 07:39 PM   #4
Square_78
Square_78's Avatar
are you removing the "crossmember" or just the upper control arm? The "crossmember" is the huge 3 foot long piece of steel that holds both left and right suspension as well as the engine into the frame.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 11-10-2012, 07:59 PM   #5
c10boob
c10boob's Avatar
That would be the confusion, my lack of terms! Sorry about that. Yeah, I just need to remove the upper control arm, and it's stuck due to the "thing" circled in red in the picture, which I was referring to as the crossmember
Old 11-10-2012, 08:13 PM   #6
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Do you have the ball joint seperated?It and the tie rod end would cause binding.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 11-10-2012, 08:14 PM   #7
c10boob
c10boob's Avatar
Yeah, everything is removed. Ball joint is separated and the bushings are removed from the upper control arm, etc.
Old 11-10-2012, 08:21 PM   #8
lolife99
67-72 parts collector,…
lolife99's Avatar
Do you have any pics?
It must be rusted to the studs.
Keith
Convert to disc brakes.
Old 11-11-2012, 09:10 AM   #9
Square_78
Square_78's Avatar
Is that pic you posted about your actual truck? Try some good penetrating oil and soak those studs over night. You may have to put some heat on the control arm to get it to break loose from the studs.
#teamlongbed
