Old 10-21-2003, 11:11 AM   #1
dubie
dubie's Avatar
Long water pump
I have the 9" long water pump on my 350. This engine will be moved up to the factory V8 location and I will be installing a 4 core rad as well. Will I have any problems with the clutch fan being to close to the rad or possibly hitting the rad?
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 10-21-2003, 11:18 AM   #2
tom hand
CCRider
tom hand's Avatar
Long water pump and accessories work best in the I-6 position...If thats what you have I would not move it unless you are going to change over to the short waterpump stuff
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 10-21-2003, 11:35 AM   #3
COBALT
COBALT's Avatar
I run a long water pump in the stock V8 location, and I use a clutch fan. It sits deep in the shroud, and you can't use a spacer, but it works pretty well. It sure is a pain to get new belts on, etc. Not a lot of room in the front of the motor.
When I changed the engine mounts (which is how I knew it sat in the stock location - mounts have never been changed) I had a HELL of a time getting it to sit right, and I had to end up adjusting the shroud so the fan wouldn't hit it.
I'll be swapping over to a short water pump later on so I can get a better setup.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 10-21-2003, 12:10 PM   #4
dubie
dubie's Avatar
would switching to an electric fan help eliminate this problem?
Old 10-21-2003, 04:53 PM   #5
Mixup
I have a long water pump in the V8 location with a clutch fan with no problems. I did have to cut a little bit off the shroud to get the fan to sit half way in.
1980 Chevy Shortbed Pickup
1969 Z28 engine
Turbo 350
Mixup is offline   Reply With Quote
Old 10-21-2003, 05:33 PM   #6
COBALT
COBALT's Avatar
Well, there really isn't a "problem" per-se. I mean it will work just fine assuming you're not using some big-ass fan, and your shroud is set up right. Since I adjusted mine all I have to do is lean on the shroud while the engine is running and...
BAP BAP BAP!
Seattle, WA.
