Choke Plate - Monojet
Can anyone tell me what the piece in the center of this choke plate is, what it's for if anything, and is there anything additional missing from it? Finally, should it stay or should it go?
Active Member
![]() Join Date: Jul 2007
Re: Choke Plate - Monojet
I'll look at mine to see if they have the same.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
Active Member
It's for a vacuum break. Probably not needed if you have choke cable. Mine was un hooked. Scroll down this page for a parts break down.
Pics.
Thanks for identifying that. I have not seen that illustrated anywhere else except on your link. My vacuum break just (exterior in picture) just passes through the rubber seal and terminates after about 3/4". I'm not presently looking at it, but I can't recall if it looked severed off or not. I do not have a manual (in cab) choke, nor is it electronic, I believe it is a bi-metal spring on manifold type. Am I actually missing something, like the rest of the shaft that connects to the choke plate? Or is this a 69 Monojet design change? I'd like to sort it out before I reassemble. Thanks again for the input.
