Old 11-13-2012, 08:06 PM   #1
Auctioneerhere
Pictures of a BBC installed needed
Looking to see what type of clearance I would have for headers in the future.
Auctioneerhere is offline   Reply With Quote
Old 11-13-2012, 08:21 PM   #2
suxtobu65
suxtobu65's Avatar
Re: Pictures of a BBC installed needed
Im in the same boat. Im still trying to shoehorn my bbc into my 65. Others have said headers for a chevelle. I have headers from my 88 cclwb dually im attempting to use. Have to make my own engine mounts to have clearance.. still trying to find a radiator.
suxtobu65 is offline   Reply With Quote
Old 11-13-2012, 08:27 PM   #3
Bearcamp
Put the radiator in the rear and remove the inner fenders. Just a thought. My 37 I puit the radiator in the rear and works great.
Bearcamp is offline   Reply With Quote
Old 11-13-2012, 09:03 PM   #4
chevytrucknut61
chevytrucknut61's Avatar
A good friend of mine put a big block in his 65 Here is a link to his web albums with some pics of what your looking for. Hope this helps!
http://picasaweb.google.com/fritz199090
He moved the motor mounts to the front to give room for his HEI.
chevytrucknut61 is offline   Reply With Quote
Old 11-13-2012, 09:35 PM   #5
66farmer
66farmer's Avatar
The BBC fit great I had to adjust the firewall just a little . I used Sanderson headers no problems.
66farmer is offline   Reply With Quote
Old 11-14-2012, 12:48 AM   #6
argonaut
argonaut's Avatar
402 with stock big block truck manifolds, in a 64 C10, with big block motor mount perches from a 71. It moved the whole powertrain assembly about 3" forward in the frame. The perches and the engine bolted right in. I did have to shave the upper flange of the frame rail, similar to the 71 with a big block.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 11-14-2012, 01:15 AM   #7
Auctioneerhere
Thanks!
I am new to this site & have been really impressed with the information here & the sharing that goes on.
Old 11-14-2012, 01:57 AM   #8
Captainfab
60-66 Nut
What I have done is trimmed the top flange of the frame, using a '73-'87 frame as a template. Then you can use headers for a '68-'72, or '73-'87, or the Chevelle headers. Either way, you will not be able to use a mechanical clutch linkage, if you want to run a manual trans. You will be better off converting to a hydraulic clutch in that instance. If you choose the Chevelle headers, I believe the bellhousing crossmember has to come out.
Old 11-14-2012, 02:20 AM   #9
Auctioneerhere
H'mm I am going to run a 4 speed, so I am going to have to fab up something there. I am planning to use a 73 & newer frame so hopefully that will make a difference.
Old 11-14-2012, 06:42 PM   #10
Chevy Fleetside
Chevy Fleetside's Avatar
http://www.67-72chevytrucks.com/vboa...d.php?t=259536 Lots of pictures
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
