700r4/Converter-etc
This is going on local CL in a few days if nobody on the site wants it.
I have a 2wd 700r4 built by Premier Performance for sale. It ran fine when I pulled it a few months ago. It is the late 80s 30 spline model with a stage 2 package from premier. It has about 45K on it. I also have a brand New in the box B&M lockup Holeshot converter. TCI manual lockup kit, B&M "corvette" kick down valve, assorted GM speedo gears (to calibrate speedo), and the OEM flexplate and a "JM"The Wheel"" solid 163 tooth flexplate. Also, a used good working B&M megashifter and brand new in the box B&M heavy duty shifter cable. I have all the receipts/installation instructions. I would plan to have the trans inspected and freshened up since you have to partially disassemble anyway to install the lock up kit. Price is $600 firm. Prefer local pickup but will ship on your dime. I'm in S AZ. Not breaking it up at the moment. Thanks for looking. |
Re: 700r4/Converter-etc
Oh man, this is tempting. Hard to find these trannies for some reason.
'67 C20 LBW |
Open to trades? I have a set of buddys that need recovered.
1970 GMC 1500 stepside 1972 GMC Jimmy Custom 2004 Chevy Colorado 1989 Swb Silverado 1972 Aj's Stormer |
Thats a Steal of a deal................too bad in im oregon
Measure with a yard stick Mark with Chalk Cut with a torch ![]() Built it yourself, don't count on others to to do it for you or with you. It will never get done |
pm'ed you
1972 C10 LWB Cheyenne Super ![]() God Said,"Owning A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still Gay" ........................__ ..........._______ |__\__ ..........|__(O)______(O)] |
Did this sell?
When you pulled the transmission did it still feel fresh? Was there any issues with it.
#11 | |
Yes, its got a pretty decent kit in it. It chirps the tires on the 1-2 shift. I have been meaning to swap in the lockup convertor and kit for some time, but I rarely drove it (no A/C in AZ ![]() It has about 40K miles on it, mostly highway. If it were me, I'd have someone just take a look at it inside, while its partially apart to put the lockup function back in it. I dont know how long good clutch plates last, but they are fairly cheap. If you dont put the kit in it, you will have to use a non-lockup convertor until you do. |
Im new to these transmissions this work with a c10 right with some mods?
1970 GMC 1500 stepside 1972 GMC Jimmy Custom 2004 Chevy Colorado 1989 Swb Silverado 1972 Aj's Stormer Last edited by mgkgmc; 11-15-2012 at 05:40 PM. |
![]() Join Date: Jun 2005
What is the stall on the Holeshot convertor?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
Ill take it.
#15 |
Sold.
