Old 11-15-2012, 10:30 AM   #1551
mcbassin
Still Learning
mcbassin's Avatar
Re: '66 Sunbeam Minx Project - F20C/6sp/4-link/Discs...
Awesome collection of rides you have Frizz! Looking forward to the painted version and progress on the Hoe. Keep the pics and vids coming.
Old 11-15-2012, 06:16 PM   #1552
Frizzle Fry
Frizzle Fry's Avatar
Originally Posted by Pop's C-10 View Post
Moving tha rear part up to the top of the firewall would give you more clearance to pull it or remove th valve cover if need be...unless you droping it out the bottom..then you good..lol
The rear bar is attached to a reinforced area not just sheetmetal. See the spot welds next to the scab-plates? So that's where it's going. I can get the sparkplug cover off and remove the oil cap no problem. The engine already had to drop/tilt to R/R.
Thanks man! Will do.
Frizzle Fry is offline   Reply With Quote
Old 11-15-2012, 11:58 PM   #1553
Frizzle Fry
Maybe I should do something like this for the rear bar:
-or-
Can't seem to find one in 1"OD though...
Old 11-16-2012, 12:11 AM   #1554
hgs_notes
GEARHEAD
hgs_notes's Avatar
Make them yourself then.
hgs_notes is offline   Reply With Quote
Old 11-16-2012, 01:48 AM   #1555
Frizzle Fry
Need a mill and lathe to make them that nice.
Old 11-16-2012, 07:40 AM   #1556
Pop's C-10
Pop's C-10's Avatar
I wasn't questioning tha strength..jus wondering about tha clearance..my bad for interjecting
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 11-16-2012, 10:11 AM   #1557
Frizzle Fry
No worries. I'm just considering valve cover removal now...
Old 11-16-2012, 11:38 AM   #1558
watahyahknow
watahyahknow's Avatar
maibe you could make the flange on top of the springtowers so that you can weld both parts ontoo it thats the eaziest way i can see it done with the tools you have
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 11-17-2012, 01:24 PM   #1559
Frizzle Fry
Would have to make it bolt to the firewall in that case. I have some ideas I'll play with. Look what you've done Pop's!
Old 11-17-2012, 09:51 PM   #1560
Pop's C-10
Pop's C-10's Avatar
My bad FF..lol
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Old 11-20-2012, 04:02 AM   #1561
68 TT
Still plays with trucks
68 TT's Avatar
A double shear tabbed connection is plenty strong for a strut tower bar. No lathe or mill needed to make those.
I have been running this type of connection on transmission crossmembers for 25 years in all kinds of drag cars & muscle cars with no failures.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 11-20-2012, 09:57 AM   #1562
Are we done yet?
Old 11-20-2012, 10:13 AM   #1563
Frizzle Fry
This is becoming the Winchester Mystery Car...
Old 11-20-2012, 11:55 AM   #1564
sparkydog
sparkydog's Avatar
Well there's your answer - fab up a mill and a lathe first!
Balls and a Sawzall
Project Halfbreed
Porsche 944 L67V6 CARB Legal & Other Stuff
sparkydog is offline   Reply With Quote
Old 11-20-2012, 12:29 PM   #1565
ERASER5
ERASER5's Avatar
I ain't afraid of no ghost! Not even the Stay Puff Marshmallow monster!
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 11-21-2012, 01:40 AM   #1566
pickup67man
pickup67man's Avatar
Are you going to have a staircase in the trunk that ends at the roof?
Travis
2005 K2500 Duramax (hauls the junk home)
1967 Chev C10 (hauls a$$)
1970 Suburban (Yukon XL 4 door)
1968 GMC 3/4 ton (sheetmetal only, chassis gone)
2005 Malibu (wife's car, still a Chevy)
Project Family Hauler
New Home for Chevys (Moved in and working)
pickup67man is offline   Reply With Quote
Old 11-21-2012, 10:27 AM   #1567
Frizzle Fry
wouldn't be complete without one would it?
Old 11-27-2012, 07:46 AM   #1568
76C10Stepside
76C10Stepside's Avatar
ATTENTION, FRIZZ! Here's a Hillman Country Estate Town Car wagon to go with your Sunbeam Minx: 1957 or 58 Hillman Station Wagon - $900 (Rochester)
76C10Stepside is offline   Reply With Quote
Old 11-27-2012, 05:16 PM   #1569
Frizzle Fry
Hah, thanks man That one has been on CL for a while now ...sad. I've actually been offered a Minx Estate free from a guy in CA. Would love to have one. Just can't justify it right now. Not even for free with the cost of transport.
Old 12-06-2012, 07:32 AM   #1570
blind studios
Great job on the build!!
Not sure if you're past your strut bar clearance issue, but these could help....
http://shop.thefabsource.com/1-Tube-...702000-065.htm
1" tube joints would look really trick in there.
-Jeff
blind studios is offline   Reply With Quote
Old 12-06-2012, 05:03 PM   #1571
Frizzle Fry
Thanks Jeff. Those are sweet. I'll have to look for another use for them. I decided to scrap the rear bar/brace. Gotta get this thing done!
So I finished the lateral shock tower brace:
Old 12-06-2012, 06:19 PM   #1572
Frizzle Fry
More debug pay-off; the brake pedal needed a few upgrades. The cover was added to keep the wiring harness off the lever (moving parts). Nuts welded on to ease installation. Bracket installed to provide additional support. Not shown is the pedal moved to the left to provide more go-pedal room:
Old 12-06-2012, 07:04 PM   #1573
Frizzle Fry
Did a little more wiring clean up (no pics). Then pulled the engine one last time..!
Old 12-07-2012, 12:17 AM   #1574
El Campo
El Campo's Avatar
Great looking brace! All looks so good
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
Old 12-07-2012, 10:33 AM   #1575
Frizzle Fry
On a side note: OMFG!
