11-13-2012, 09:26 PM | #1 |
Rear Axle options?
Hello all new here, I have a 69 C-10 long bed. The rear axles were put in a short bed, I was left with 69 6 lug axles and front spindles, (The spindles were just put on to be able to move the truck around.) The front has the 72 cross member. So the front is easy and I plan on lowering the truck with drop spindles anyway. However when the swap on the rear axles was done we noticed that the rear gears were broke. So I have 73 - 87 truck sitting here along with a 96 rear end, Will one of these other rears swap in? I have the coil spring rear, and I know that some some of these trucks have leaf springs, so I got to wondering why wont one of these other axles work? This one has been in the faimly for several years, it was orginally my brothers and we did some trading. and I ended up with what is left. Can i just swap the gears and axle shafts?
Also Is there a way to go to a one piece drive shaft? |
11-13-2012, 10:09 PM | #2 |
Happy to be here
Re: Rear Axle options?
You can add the correct spring perch to the 73-87 axle,but that wont allow you to mount your panhard bar. You would need to fab a mount or locate an aftermarket kit to make it work.
11-13-2012, 10:12 PM | #3 |
What about just swapping to leafs doing away with the coils?
11-14-2012, 11:34 AM | #4 |
Happy to be here
You can do that, but its not a direct swap. The frames are the same up front, but not in the rear. You will need leaf spring hangers from a 67-72 truck.
11-14-2012, 07:56 PM | #5 |
The later rear ends are wider as well (another thing to keep in mind).
11-15-2012, 12:30 AM | #6 |
I was told that all GMC 67-72 were the leaf and the chevy's had the coil is this true? or are they year and package specific?
Ty do you know how much wider? Sounds like i just need to source a coil spring rear and stick to stock. What about the Gears? will the gears from a later model rear fit in my 69 -72? Like I said i have several laying around and could just use the gears in my housing. Will the pinion swap as well? Just trying to use what I have if I can. |
11-15-2012, 09:54 AM | #7 | |
6x-70 rear ends are about 62", 71-87's were approx ~63.5", 88-98's are approx 65". Gears will depend on the housing. 10bolt housings use smaller diameter ring gear set-ups & wouldn't interchange (many late model housings are 10bolts).
11-15-2012, 03:11 PM | #8 |
so is that extra inch and a half a big deal? if i find some spring perches? i plan to lower it and i wont be running 20s
11-15-2012, 03:32 PM | #9 | |
I like a narrower rear end width to allow running deeper dish rear wheels & still fit within the tub area better on a lowered truck (my stuff is usually dropped).
11-15-2012, 04:59 PM | #10 |
I read somewhere that the 69 6 lug rear is narrower than the 5 lug by 1 1/2.... if this is true, does that make the 10 bolt the same size as the 5 lug or is it an additional 1 1/2 making it 3 inches in total more width over my current axle? or am i just getting my numbers confused?
I dont mind the extra 1 1/2 width because I dont like how the rear looks sunk in compared to the front anyway. I plan on running 17s with 60s maybe 50s all the way around with a drop and a nice rake. so i am not seeing the extra width axle being a problem. Also will the yoke be the same from the years? Also I saw a post where a leaf spring axle was used on a coil set up like mine. what all would be involved with that you think? |
11-15-2012, 05:38 PM | #11 | |
63.5" (5-lug rear ends) - 62" (6-lug rears) = 1.5" difference. 88-98 housings are 65" or an additional 1.5" wider than the 71-87 5-lug housings. Leaf rears can be swapped into a coil truck. You just need the appropriate mounting pads for the swap (Porterbuilt had them @ one time & Early Classic Enterprises has them). Yokes are diff as far as the housing sizes are slightly different. Beyond that, I'm not sure.
11-15-2012, 05:44 PM | #12 |
~Rest In Peace~
same here here where i had narrowed by 3 inches for deep bs wheels
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
11-15-2012, 07:19 PM | #13 |
To avoid confusing Ndkshns, I was referring specifically to the housing width. There are multiple ways to accomplish the deep dish desire.... On a 67-68 coil suspension truck (OE dimension truck arms w/coil-overs), I had a 15" wide rear wheel w/o having to touch the frame rails.
11-15-2012, 08:43 PM | #14 |
I am not looking to tub this thing just get it on the road this is the desired look and stance I want!
[IMG][/IMG] Thank you for all your info. I now know my options: find a 6x -72 coil rear swap to five lug axles, find a 6x- 72 leaf do entire swap... use a 73-87 be a lil wider in the rear change yoke on Drive shaft to fit. modify axle perches source perches for the axle. What about a '66 Gmc rear axle? I forgot i have one of those as well.....its a 6 lug and thats a manual truck where my truck is an auto... just another option I may have. |
11-16-2012, 09:39 AM | #15 | |
11-16-2012, 09:52 AM | #16 |
Senior Car Nut
'71 and '72 rear housings are trailing arm/coil springs and a direct bolt-in AND are 5 lugs. they are 1.5" wider that is true, I have one in my "66.
I'd say you'll want an adjustable panhard bar and a shock relocater kit if you're dropping it
Larry Last edited by fleetsidelarry; 11-16-2012 at 09:58 AM. |
