Old 11-18-2012, 07:19 PM   #1
chewychevy67
Can i reuse these axle bearings
67 Dana 44 rear axle. I had these bearings pressed on and they were brand new. They have not even been used on my truck yet. I had them pressed back off to powdercoat the ends. Now my question being that they are still brand new can i have these and the same collors pressed back on or am i looking for trouble doing that. Rod.
chewychevy67 is offline   Reply With Quote
Old 11-18-2012, 07:40 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Can i reuse these axle bearings
Interested to see what others will say..... seems like there should be no problem as long as they haven't been damaged in the process, and I wouldn't think they would be damaged. Unless I saw/felt something wrong with them, I would use them.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 11-18-2012, 07:46 PM   #3
chewychevy67
they still feel smooth and tight. just not sure and would like some input before i make a decision.
Old 11-18-2012, 08:02 PM   #4
clinebarger
Replace the bearings & lock rings, Don't risk an axle coming out or having to take the axle back out over a bearing.
clinebarger is offline   Reply With Quote
Old 11-18-2012, 08:06 PM   #5
LockDoc
The Older Generation
LockDoc's Avatar
Myself, I wouldn't hesitate to re-use them as log as there is no visible damage.
LockDoc
Leon
Old 11-18-2012, 08:23 PM   #6
hayhauler71
hayhauler71's Avatar
LockDoc
exactly what I was thinking
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 11-18-2012, 09:02 PM   #7
SS Tim
SS Tim's Avatar
Originally Posted by chewychevy67 View Post
... I had these bearings pressed on... I had them pressed back off...
End game you cycled the lock collars or more correctly had someone else do it. If they were very careful and used a splitter that fit very closely and was loaded evenly the bearings might be usable. Often bearing damage will not show up without a load or a little use. The lock collars are done even if you are sure which axle they were on.
SS Tim is offline   Reply With Quote
