Closed Thread
Old 11-16-2012, 12:15 PM   #5351
ScottG
Re: What did you do to your truck today!
Originally Posted by magwakeenercew2jh View Post
Let us know....PLEEEEEZE!!!!???
It'll be a bit before I get everything together to install it, but I will post the improvements, if any.
'67 C20 LBW
ScottG is offline
Old 11-16-2012, 02:29 PM   #5352
Shyguy
Junior Member
Shyguy's Avatar
We took the stepside bed up to my son's house since we are now ready to start getting it ready for painting.
Washed it down good, removed the tailgate and the chains.
Tomorrow we will weld in the roll pan, then see what else we have time to do.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline
Old 11-16-2012, 04:59 PM   #5353
Big Block
Big Block
Big Block's Avatar
Originally Posted by 1972SUPERSB View Post
Rebuilt my front end on my 72. Wow lots of work!
Should make driving it more fun. It gives you a reason to clean things up on the underside of the truck too.
Big Block is offline
Old 11-18-2012, 09:41 PM   #5354
54belair
54belair's Avatar
Well, I finally got the under side of the cab finished today.
We did alot of welding to the cab floors while it was still on the chassis, then I put it on the rotissary to finish up the bottom. Got all the pcs welded in on the bottom, seam sealed every joint and seam underneath, two coats of por 15. Now its time to lower it back down and seal/coat the floors top side. Not too far from getting the cab in epoxy primer like the front clip and bed.
Very soon it will be time to play mechanic instead of bodyman. On to the frame!!
1997 shortie stepside
1968 short stepside
1966 mustang
1966 chevelle ss
Dont always go the cheapest route--You can save yourself into the poorhouse!
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=489030
54belair is offline
Old 11-18-2012, 10:29 PM   #5355
thelonerife
thelonerife's Avatar
put some under dash lights and a glove box light in.
thelonerife is offline
Old 11-18-2012, 10:30 PM   #5356
Z10
Z10's Avatar
After I purchased my 72 GMC back in August and got it home, I discovered I had no horn. Everything else was there so I started thinking about what to buy.
I stumbled across an ebay auction last week for horns off of an 87 Cadillac. Not 1, not 2, not 3 but 4 horns. So, this afternoon I got around to mounting them.
"LOUD"
My little stepper sounds like a West bound train at a railroad crossing. Sweet!
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline
Old 11-18-2012, 10:44 PM   #5357
dliving69
dliving69's Avatar
Well this past week, water pump went out so I swapped a new one in and then headed home and the damn belt busted, so now thats getting replaced tomorrow. Also found out I have 3.73 posi trac rear end. Ready to get it back running.
dliving69 is offline
Old 11-18-2012, 11:04 PM   #5358
dliving69
dliving69's Avatar
I was wondering, too.
The sun came out today, so I finished up the head/parking light switch and the "dummy" choke button set up. Replaced the hand-brake and the hand brake cover.
Put the steering wheel on loosely for a "final" test fit. You might notice the little button on the dash next to the ashtray. I got sick of screwing around with the horn.
And, the hole was already there...Some P.O. got drill-happy, I guess. Now, it's a teeny horn button.
Oops! Can't see it in these pics....
Nice truck! from what I can see. What are them seats out of? and what all did you have to do to make them fit? I have a bench seat
Old 11-18-2012, 11:11 PM   #5359
dliving69
dliving69's Avatar
"Finished" putting in the new dash...and new glove box door, thanks to a great deal from a Forum Member. Made my new SPI decal and "stuck it".
That was after threading in the new M & H under-dash harness...simple and smooth install.
Looks like the "new" (reclaimed from the parts stash) fuel gauge is gonna work. Can't say why....One of those deals that since you're working on so many ends of the thing,
and EVERYTHING has to work together for the proper end result, I have no idea why it works now. The suspected "pinning" was okay in the plug for the new printed circuit. New plug
(M and H). New ..tested...sensor/float (Summit). New wire to the tank (Magwa). New...tested...fuel gauge (70's GM from the stash). New Fuse Box (M &H). I dunno!
If it didn't work, I'd really be scratching my head. News at 11.
How's this for an SPI? Bet it will confuse someone down the road....
Where did you get that glovebox at, I have a original ac cab.
Old 11-19-2012, 02:51 AM   #5360
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Thanks, dliving69
In the Vintage Air kit.
The seats are out of a 2004 Blazer.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 11-19-2012, 09:46 AM   #5361
bk2life
Asked the machine shop wtf is taking so long to put my motor together…
bk2life is offline
Old 11-19-2012, 06:01 PM   #5362
mcmlxix
Collector of Projects
mcmlxix's Avatar
Test fit the NP205 to the 4L80e and had my friend Russ (the robot) tig weld the adapter...
Rich
1972 K5 Blazer CST Click HERE
mcmlxix is offline
Old 11-19-2012, 06:14 PM   #5363
in deep 72
in deep 72's Avatar
Nice adaptor! I was going to go the same route, 4l80e and 205, but had my transmission guy talk me out of it (that and the cost of the electronics needed). Now trying to sell the 80.
in deep 72 is offline
Old 11-19-2012, 08:09 PM   #5364
nlped
nlped's Avatar
Got my frontend aligned after swapping all the brakes, drop suspension and steering. The guy did a very thorough job considering the change in stance and all
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline
Old 11-20-2012, 04:56 AM   #5365
c10srule
c10srule's Avatar
finished dads bed floor, put the hood and tail gate on, just about done, will put the exhaust on tomorrow then dad has to do some finishing touches, turned out to be a cool old truck
c10srule is offline
Old 11-20-2012, 08:49 AM   #5366
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Welded some bump stops on yesterday.........
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline
Old 11-20-2012, 11:36 AM   #5367
RexDodge
Booya! Got the first layers of epoxy on! Special thanks goes out to JRE (Justin). Now on to the details and slicksand.
RexDodge is offline
Old 11-22-2012, 12:04 AM   #5368
Shyguy
Junior Member
Shyguy's Avatar
We cleaned and straightened my son's garage, since we are done with building my '67 swb stepper. Then we pushed in his next project.
Shyguy is offline
Old 11-22-2012, 10:17 AM   #5369
ChillWinstonC20
ChillWinstonC20's Avatar
Shyguy, looks like you and your son did an amazing job on that stepper. Can't wait to see his c10 project! Love the stripes on cowl. Did you guys have a build thread anywhere? I'm curious what the rest of it looks like
ChillWinstonC20 is offline
Old 11-22-2012, 10:33 AM   #5370
UNEASYRIDER
UNEASYRIDER's Avatar
Built me a box and installed to test it out
DON'T BUILD IT IF YOUR NOT GONA DRIVE IT!!
UNEASYRIDER is offline
Old 11-22-2012, 12:51 PM   #5371
c10srule
c10srule's Avatar
cleaned it and took it out to beat on the tires
c10srule is offline
Old 11-22-2012, 12:53 PM   #5372
c10srule
c10srule's Avatar
changed the fuel tank float in our dogs truck
c10srule is offline
Old 11-22-2012, 01:18 PM   #5373
magwakeenercew2jh
Tip: Make sure that is fully out before you put it back in the tank. Otherwise, you run the risk of having a hot dog.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 11-22-2012, 02:26 PM   #5374
c10srule
c10srule's Avatar
pretty cool, pitched it in some water then it went in the trash can
c10srule is offline
Old 11-22-2012, 03:25 PM   #5375
bsteele
The rear end was leaking so I pulled the cover off, cleaned it, re-painted it and re-installed. Also painted the master cyclinder since I am finally getting to drive it and it was starting to show a little rust. Lastly I fixed the shifter. I had hooked up 1st and reverse backwards. It was interesting the first time I started to pul off. Now it is time to go to the in-laws to eat. Happy Thanksgiving to all. I'll ask everyone to take a minute today and really think about what you are thankful for. Tell the people you love how much you are thankful for them!!
bsteele is offline
Closed Thread
