Old 11-19-2012, 12:21 AM   #1
leddzepp
Moderator
leddzepp's Avatar
Excellent condition tilt column
Here is a tilt column I pulled from a low mileage van. It is in excellent condition, and complete with all parts. No broken parts, very tight and solid. The shifter is solid, no play whatsoever, and the shift pin needs to be removed with a center punch and installed with a hammer. The detent has no wear and this will NOT slip out of the Park position. This column is not a core for rebuild...it is ready to use. I added the correct truck tilt/turn levers, and the horseshoe wire harness adapter so that it will plug right into a truck. $280 Shipped in the conus. Shipped means packed proprerly in an oversized box, with plenty of bubble wrap to ensure the shift collar does not get bent up in transit (seen this happen more than once).
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 11-19-2012, 12:27 AM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: Excellent condition tilt column
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 11-19-2012, 12:28 AM   #3
47thriftmaster
47thriftmaster's Avatar
Do you have more picks, close ups, is the hazard switch in good shape? If all looks good I'll take it.
47thriftmaster is offline   Reply With Quote
Old 11-19-2012, 12:30 AM   #4
leddzepp
Moderator
leddzepp's Avatar
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 11-19-2012, 12:35 AM   #5
leddzepp
Moderator
leddzepp's Avatar
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 11-19-2012, 12:35 AM   #6
leddzepp
Moderator
leddzepp's Avatar
Sorry iPhone flips the pics for some reason
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 11-19-2012, 12:47 AM   #7
leddzepp
Moderator
leddzepp's Avatar
Hazard switch is the OEM van style, and functions as it should. Can be unscrewed and the "horn" style substituted.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 11-19-2012, 07:50 AM   #8
blazercrazy70
blazercrazy70's Avatar
I can't remember is there anything you have to do but bolt it in. I am interested if thriftmaster does not want it.
blazercrazy70 is offline   Reply With Quote
Old 11-20-2012, 03:54 AM   #9
47thriftmaster
No, should just bolt in. I will have to pass, but it is a good looking column for the price.
Old 11-21-2012, 02:44 AM   #10
Z10
Z10's Avatar
I'm interested in the column. You'll have to forgive my ignorance, is this a direct bolt in for a 72 GMC?
Thanks,
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 11-21-2012, 03:21 AM   #11
leddzepp
Moderator
leddzepp's Avatar
Thanks,
You need to collapse your intermediate shaft, as described here: http://67-72chevytrucks.com/vboard/s...d.php?t=133937
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
