Old 02-27-2010, 03:50 AM   #1
chopped68
Cold metal
here is my build.it has been on the road for a year.lots of nights and weekends.Name:  21710-00.JPG
front sheet metal was beat up to much to save
had a small head 454(small port heads,not worth keeping)
getting ready to chop the top
chopped68 is offline   Reply With Quote
Old 02-27-2010, 03:52 AM   #2
Ronm909
67GMC Slammed
Ronm909's Avatar
Re: Cold metal
subscribed!!!
my dropmembered 67 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=383215
Ronm909 is offline   Reply With Quote
Old 02-27-2010, 04:00 AM   #3
chopped68
Re: Cold metal
more picsName:  21710-5.JPG
chopped 6 inches in front & 5 inches in back
no more sun in my eyes!!
so much rust i had to rebuild this entire front edge,good way to get sheet metal experience
the leading edge was replaced from door to door
Old 02-27-2010, 04:10 AM   #4
chopped68
Re: Cold metal
stitching it back together.pay attention to the door handle!
removed the stock door handles.i dropped the handle location 3 inches and
put on 1966 door handles(looks much better to me).let me know what you guys and gals think.
Old 02-27-2010, 04:30 AM   #5
chopped68
Re: Cold metal
more picsName:  21710-15.JPG
they messed up the bedsides when they put the auxilliary tanks in
all better now
interior gas tank is gone! my bucket seats are in its place
rust in the usual areas.
previous owner butchered this hole in the kick panel area
Old 02-28-2010, 04:41 AM   #6
chopped68
Re: Cold metal
everything but glass & paint was done in the garage at the apartmentcomplex I used to live in.here is more pics.
rocker panels,a pillars and 3 inches of the floor by the rockers were replaced on both sides
Old 02-28-2010, 04:45 AM   #7
chopped68
Re: Cold metal
Old 02-28-2010, 05:02 AM   #8
chopped68
Re: Cold metal
i sectioned the inner part of the roof so I would not have to split the ribs
the truck used to have a camper on it,there was boot snaps around the rear window that got welded closed
in this pic you can see the rain gutter was boxed all the way around and extended a couple of inches down to the body line
a perforated metal panel was used to make trash guards
Old 02-28-2010, 05:12 AM   #9
chopped68
Re: Cold metal
cleaned up front suspension and installed 2 1/2 inch drop spindles
airbag suspension installed but ended up changing the bags from firestone to slam specialties.that allowed me to remove the upper & lower bumpstops.the swaybar is also gone now.I used the firestones to replace the old ones on my 65 belair
Old 03-03-2010, 01:45 AM   #10
chopped68
Re: Cold metal
it's been busy around here for the last couple of days but I had some to post more pics.
67 fenders were used to eliminate side marker lights
320hp 350ci(bought it complete with 8000 miles for $800.00) with a turbo 350 transmission that I built
picked up 2 grill shells on ebay for $450.00.1 in good condition,1 mint condition!
Old 03-03-2010, 02:06 AM   #11
chopped68
Re: Cold metal
I did a 2 inch notch,made the radius plate and boxed it.
checking clearance before finishing
I cut the stock shock mounts and gave them some style.I know nobody will probably see them but I will!!
getting ready to build the bed skeleton to hold the 4 rib aluminum floor.truck
had a wood bed but would not be practical for me since I will be hauling tools
& metal for working on cars.
another good use for an engine hoist
Old 03-03-2010, 02:18 AM   #12
chopped68
Re: Cold metal
bed skeleton done,I did the bed with roll on bedliner and the 4 rib aluminum sheet is being put in with a little shaving.
my other daily driver.1965 belair(bagged also)
the gate had some damage but cleaned up well.
Old 03-03-2010, 02:29 AM   #13
chopped68
Re: Cold metal
interior is almost done.'slightly' modified quicksilver shifter.
center console is made from some 18 ga sheet matal and a damaged roof exhaust fan.air gauge mount is done out of 3/8 round bar,exhaust tube and
3/16 plate.
snare drum gas pedal from 1965.og lowback bucket seats from beard bolted to the floor.
Old 03-03-2010, 02:41 AM   #14
chopped68
Re: Cold metal
ready for paint
just a couple of things to put on and ready for glass.truck was painted with
hot rod flatz,cut with 2000 grip and buffed with dull rubbing compound
hood is ready to go on
A BLAST TO DRIVE!!
getting ready for an additional 4 inches of drop in the rear and some front fenderwell work.when done,I will be able to drive it aired out.
Old 03-03-2010, 11:38 AM   #15
marcsRX
68 C10 SWB
marcsRX's Avatar
Re: Cold metal
I like your style.
"How much physical pain do you go through on a daily basis that you can directly attribute to your lack of intelligence?" -R0bman
marcsRX is offline   Reply With Quote
Old 03-03-2010, 07:33 PM   #16
Scott Webster
Sheetmetal Psycho
Scott Webster's Avatar
Re: Cold metal
Pretty sweet
I didn't say you were stupid, but I was thinking it... I need a check up from the neck up!
Project "Rigginstine's Monster"
1971 C-10 longbed 355/4spd
Future mods: 67 front clip
Webby's Rigginations - where everything has potential!
Scott Webster is offline   Reply With Quote
Old 03-07-2010, 07:56 PM   #17
LoX_69
LoX_69's Avatar
Re: Cold metal
Glad to see the build thread....thats one bad ass truck
LoX_69 is offline   Reply With Quote
Old 03-07-2010, 08:49 PM   #18
tcb-1
Nothing to see here.....
tcb-1's Avatar
Re: Cold metal
dig it!
are those factory steelies?
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 03-09-2010, 01:21 AM   #19
chopped68
Re: Cold metal
thanks for the props guys.i burned up a makita 4" grinder building the truck!
lox 69 , if i would have known about this site when i started the build,i would have taken alot more pics.right now i'm waiting on my stepnotch kit from thorbecke bros..going to modify wheelwells,get some stock trailing arms(doing a 3" 'z' on them) and have already re-routed the exhaust and drop the rear another 4-5 inches.there will be alot of pics on this.
tcb-1 , the wheels are from wheelsmith(santa ana,ca) 15x6 smoothies.
Old 03-09-2010, 01:34 AM   #20
Jbesotes
Jbesotes's Avatar
Re: Cold metal
Those looked like six lug disc breaks? Who did you buy them through??
'70 Chevy Shorty
I support our troops!! Thank You to all that have served!!
Jbesotes is offline   Reply With Quote
Old 03-13-2010, 01:37 AM   #21
chopped68
Re: Cold metal
jbesotes,
the front suspension was rebuilt when I bought it.I believe the disc brakes were picked up from the truck shop in orange.
ken
Old 05-23-2012, 01:52 AM   #22
chopped68
Re: Cold metal
I built a cantilever rear suspension for the truck a few months back.here is a couple of pics.1st pic shows the suicide doors step notch.2nd pic is the ece dropped trailing arm crossmember.3rd pic is my cantilever setup with integrated bag mount.last pic is the new bullet.my version of hot rod mags agent 87.it's a 383 with a hydraulic roller cam.i have more pics but they are on my digtal camera.stay tuned for a build thread on the hood mods!
Old 11-19-2012, 08:42 PM   #23
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Cold metal
Cool project! Need some details/pictures on how the rear suspension is setup
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 11-19-2012, 10:47 PM   #24
Tinkermc
Re: Cold metal
very nice
Tinkermc is offline   Reply With Quote
