Old 11-19-2012, 10:43 PM   #1
Kid
Kid's Avatar
steering column lower bushing adapter
Not much info on this forum for this subject so... For those who choose to keep their original steering column but have a later model steering box or rack & pinion, I had 5 extra flanged bushings made that fit into the stock steering tube & have a 0.820 hole for centering the original steering shaft. I know these fit the 47 to 54 columns, but not sure about other years. These make it easy to keep the look of the stock column & steering wheel. If interested, PM me for additional info.
Kid is offline   Reply With Quote
Old 11-20-2012, 12:30 AM   #2
parkwood
parkwood's Avatar
Re: steering column lower bushing adapter
www.classicperform.com sells a adapter for chevy columns called column saver. Nice piece and easy to use..
parkwood is offline   Reply With Quote
Old 11-20-2012, 10:25 AM   #3
mknittle
mknittle's Avatar
What are they made of?Looks like delren or nylon.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 11-20-2012, 01:17 PM   #4
mr48chev
mr48chev's Avatar
Make sure that your steering shaft is all lined up perfectly to operate smoothly with the bushing. I made a similar one for my 51 Mercury 20 something years ago and had the steering shaft in a bit of a bind and it was the pits to steer. The bushing isn't as forgiving as a ball bearing would be in most cases.
My ongoing truck projects:
Old 11-20-2012, 02:54 PM   #5
Kid
Kid's Avatar
I'm not against, the "#CPBCS - Billet Steering Column Saver" just the $70.00 it costs, & the 1.75" OD was too big for my 51 column (& 1.5" is too small) & I was not crazy about options of machining / swelling or centerning with set screws. My cheap nylon bushing has been working perfect since 2007. (& over 10,000 miles). Just a cost effective alternitive that cost me only $35..
