Old 10-22-2003, 12:48 PM   #1
stateamind
And you call that a what?
stateamind's Avatar
Question Driveshaft Question
Ok, so I have a 700r4 from a 92 1500 donor installed in my 71 c-10 shorty. Plan on using the driveshaft from the 92. I like the idea of bigger u-joints. I will have to get a couple inches cut out of it, but that's ok. My question revolves around the pinion yoke. I've seen them somewhere online before, but can't seem to find them again. I need one to match up with the bigger rear joint of the driveshaft. My 71 is smaller. Anyone know where I can find these? Or possibly an easier (cheaper?) way to get the 700r4 connected to the 71 rear? Thanks guys.
stateamind is offline   Reply With Quote
Old 10-22-2003, 01:05 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
I think they are called Hybrid U-joints and can be bought at NAPA. I used one to mate a 3/4 ton 4x4 driveshaft to a 1/2 ton rear pinoin yolk
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 10-22-2003, 01:31 PM   #3
lukecp
Formerly yellow72custom
lukecp's Avatar
What CPNE said....go to NAPA or a driveline shop and they should be able to get you a conversion joint
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 10-22-2003, 02:48 PM   #4
mcmlxix
Collector of Projects
mcmlxix's Avatar
I want to do the exact same thing. 700r4 in a 71 SWB .. is it a one pice drive shaft from the 92? How does it fit (lenght)?
Rich
1972 K5 Blazer CST Click HERE
Old 10-22-2003, 08:21 PM   #5
dinnut
dinnut's Avatar
id like to have a 700r4 in my truck.
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 10-23-2003, 12:25 AM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Trust me here. I've done this. Two options.
1) Driveshaft from an early to mid 80's shortbed V8 truck with factory overdrive tranny. Straight in swap as long as your engine is in the proper V8 position. I used one from an 83 short bed 305/ 700 R4 truck. Bolts in....
2) driveshaft from a 67-72 short bed 3 speed 6 cylinder truck. Again bolts in.
9 out of 10 people here do not know, but stock 67-72 short bed 6 cylinder 3 speed trucks came factory with 1 piece driveshafts. They work perfectly for this swap. I've done it twice.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 10-23-2003, 01:17 AM   #7
stateamind
stateamind's Avatar
Thanks for the great answers to my question guys.
mcmlxix - yes, 1-piece from the 92 ... looks like it's abt 2 inches too long, also has 1330 series u-joints, original had 1310 series.
