Old 11-20-2012, 05:50 PM   #1
54blackhornet
54blackhornet's Avatar
Locking Gas Cap ?
Well the only key I did not get with my new 71 GMC I bought last week was the locking gas cap ? I did get a Key marked gas but it will not turn at all ? I gave it a shot of PB Blaster but nothing, will not turn at all ? Any thoughts other than cutting it off ?.....Thanks for looking !
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 11-20-2012, 06:30 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Locking Gas Cap ?
Not worth paying a locksmith unless he's a friend who will work for free (or beer). Or try this -- if you're on good terms with an auto parts store employee, maybe they'll try some keys from similar locks. One more thought.... I once heard the small numbers on the locking cap are coded to the key. Might help you get the right key the first time. Good luck.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 11-20-2012, 07:05 PM   #3
kcsa75
kcsa75's Avatar
You need to reach out to LockDoc on the board.
Leon is wise. Leon knows all.
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 11-20-2012, 09:00 PM   #4
geezer#99
geezer#99's Avatar
Drill it out. A punch and a drill wil render it useless.
geezer#99 is online now   Reply With Quote
Old 11-21-2012, 12:56 PM   #5
54blackhornet
I was going to drill it but was concerned about filings going into the tank, I also was thinking about the little claws that lock the cap on , will they release when you drill the lock ?
71 C-20
07 Magnum RT AWD
Old 11-21-2012, 02:44 PM   #6
geezer#99
geezer#99's Avatar
If you're worried about fillings then put some grease on the bit. Grease will catch them. You don't need to drill all the way thru though.
When you get the lock cylinder out there's a slot or tang inside that activates the claws.
Or you could drive a screwdriver into it.
Old 11-21-2012, 02:51 PM   #7
54blackhornet
Thank you #99 for the help !
71 C-20
07 Magnum RT AWD
Old 11-21-2012, 02:57 PM   #8
68panelman
68panelman's Avatar
Take a prybar and piece of 2x4 and pry it off, Spin the cap until its at it's most loosest spot, the locking part is only a third notch,it should only rip up one area of filler neck that you can easily bend back to shape with some pliers
68panelman is offline   Reply With Quote
