Old 11-21-2012, 01:36 PM   #1
hfd410
hfd410's Avatar
parking brake cable question
I put all new cables on my 71 SWB. My question is on the front cable. I snapped it into the frame and ran the cable thru the firewall grommet and attached to the pedal lever. My question is, is there a clamp or something that clamps the cable down to keep it from just pushing thru the grommet? When I depress the pedal it just pushes the whole cable thru the grommet, not just the inner cable, and bows it in the engine compt between the firewall and frame if that makes sense. Any help appreciated.
hfd410 is offline   Reply With Quote
Old 11-21-2012, 06:32 PM   #2
hfd410
hfd410's Avatar
Re: parking brake cable question
Im sure its something simple that Im overlooking
Old 11-21-2012, 06:53 PM   #3
Lee H
Lee H's Avatar
There should be a small clamp that holds the cable to the inner fender. There is also a clamp that holds it to the parking brake assembly.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is online now   Reply With Quote
Old 11-22-2012, 07:46 AM   #4
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
I just went through this myself! Couldn't understand why I couldn't get the brakes to lock. Everytime I would push the pedal down, the cable housing was pulling it too.
What I found is the originals have a metal casing with spiral wires and the replacements are black smooth plastic or similar. The clamp on the brake assembly doesn't work properly for the replacement type.
To make it work for now (and it's a bit red neck-LOL) was to put a small hose clamp on the casing at the clamp location on the brake assembly. It works anyway! Keeps the casing from pulling in. Figured it would do until I think of something better.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 11-22-2012, 10:02 AM   #5
hfd410
hfd410's Avatar
Thanks guys....
