Manual tranny swap
Finally got around to dropping in my Muncie tranny after two years of talking about it. To get the hole in the tranny mount to line up with the hole in the crossmember, I had to disconnect the motor mounts from the frame and move them back. At lest the tranny is in and the driveshaft is hooked up. Anyone run into this problem before? May need to drill new holes in the frame and engine crossmember to get everything buttoned down.
Thanks, Mike Posted via Mobile Device
The Fleet........ 68' Camaro - 1st car (restored & still have it) 09' VW Tiguan (Wife's Daily Driver) 14' VW Passat SE TSI (my personal) 14' Ford Edge Sport (Daily Work Vehicle) 73' SWB Stepside - 77K org. miles 74' LWB 454/TH400 - drive train transplant for my (Sold) 98' SWB C1500 W/T - shop truck (Sold) 90' GMC Sierra SLE short step - aka " Jezabelle " (Sold) |
Re: Manual tranny swap
Not that there is a wrong way, if youre building it custom to your liking. Typically though, you leave the engine placement the same, and move the transmission crossmember, then shorten/lengthen the driveshaft.
Moving your motor rearward isnt a bad thing, if everything clears, you just took the less traveled route. |
Chevy Enthusiast
There are usually different holes in the frame for different transmission options.
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) |
some shots
No No
might be a stupid question not knowing all the details but this trans should bolt up exactly where a th350 did as far as crossmember placement what kinda trans did you have in it before?
Posted from 67-72chevytrucks.com App for Android
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
#6 | |
Should be exactly 1/4" bell housing to mount difference between the TH200 (20 1/8") and the TH350 (20 3/8"). This is what I was off. My truck was originally a 6 banger with a TH350
Pirate, have you drilled your front crossmember already? If you only have 1/4 inch difference, that isnt going to put much distance between your old and new motor mount holes. I'd be alittle concerned with swiss cheesing it up too much.
Probably will be fine, Im just anal like that. Also, its cool you finally got it installed. Granted I just joined, but awhile back I was searching about putting a muincie in mine, and came across your older threads. |
#9 | |
On a budget like Fred Sanford
Woohoo for progress! You'll be banging gears before ya know it.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
I know the pieces fit
Usually folk bolt the crossmember to transmission and drill holes in the frame to bolt it in its new spot. Make sure the dist cap is good for clearance and it shouldn't matter. How much trouble was it installing the linkage and pedals? Love the vintage valve covers btw.
![]() Join Date: Sep 2010
Hey would you mind measuring how far back from the firewall you made that hole for the shifter? im doing the same thing right now but with a supert10. How you going mechanical or hydraulic clutch?
1985 c10 355 th350 (working on 4 speed conversion to super t10) 1979 camaro 358 super t10 2003 f250 superchip slp exhaust |
#13 | |
#14 | |
#15 |
cool thanks man.
#16 |
Here you go bro. I will be heading back to Easton, Pa in about a month for X-Mas
Posted via Mobile Device Posted via Mobile Device
#17 |
#18 |
Happy Thanksgiving to all.............. Posted via Mobile Device
#19 |
awesome thanks man! Easton is only about 45 minutes from me. Are you bringing your chevy for the holidays?
#20 | |
