1963 C-10 BBC/Muncie 4 spd
63 small rear window install
I can't search because I keep getting a "fatal error". My rear window is kicking my butt. I can't figure out how it goes in. I am putting in the stock one. Does the rubber go into the track first? Do I use adhesive? Whats the easiest way to do it?
Thanks again, |
![]() Join Date: Aug 2004
Re: 63 small rear window install
WHen I did mine, I put the rubber in the sun for a couple hours, then applied it to the window, using tape to hold it on there, then put a rope around that, in the channel that the metal from the cab would fit in. spray some silicone grease in the channel, set the window in so the bottom of the rubber is like it will be when fully installed. then have a friend push on the windows from the outside, while you slowly putt the rope from inside. then when it is all completed, install the insert into the rubber gasket.
I hope that helps you http://67-72chevytrucks.com/vboard/s...ad.php?t=90510
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Just did mine this weekend. Clean the pinch weld real good. Place the gasket in window, lots of wd-40 or soapy water. Place the glass in, work the gasket all the way around then more lube and the lock strip. I did not use the rope trick. I used a modern glass tool for gaskets. Took about 40 min form start to finish.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Thank you. That worked. Just a bit tedius lol.
Senior Enthusiast
I'm curious if the chrome lock bead gave you any more grief than a plain rubber version. I'm thinking about adding the chrome bead to the rear window after the windshield trim is installed.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
My buddy Brian (in the pic) did mine. He works for AAA glass. I ordered my rear gasket from Classic Parts of America and my front from Steele. Said its the 1st classic truck hes done and took him 10-15 min. He started at the bottom by the break in the gasket, did the straight piece's then worked the corners in. Had about 1" left over, so he made it as tight as possible and trimmed. Told him to make it tight in case it shrunk. The chome strip really made an impression...I like it.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 06-04-2012 at 03:25 PM. |
I forgot to get the trim piece. I'll be ordering it today
This is the tool that he used to install the lock strip. The strip will go through the opening on the tool. Slide the triangle shaped head into the trim and it will feed the strip in as it opens the gasket. He used a "window pick" to work in the edges.
![]() Join Date: Sep 2011
I've always used the rope trick.
Past Master Triluminar Lodge #117 GL of WVa My 1963 4x4 Suburban build; http://67-72chevytrucks.com/vboard/s...d.php?t=531274 My Gallery, now with pics of my 1966 C30 motorhome. http://67-72chevytrucks.com/gallery/...&ppuser=103447 |
It'll help with the gasket, but you'll still need the tool for the lock strip.
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
I'm getting to this point.
A bump to hear from other's experiences.
It's interesting the chrome lock-bead costs the same as the black lock-bead:
http://www.classicparts.com/1955-66-...ctinfo/01-120/ http://www.classicparts.com/1955-66-...ctinfo/01-119/
#13 | |
" Place the gasket in window, lots of wd-40 or soapy water."
Good pics & ideas, 1963c-10. A glass co. right near a big auto auction sale--lots of glass work to be done in the area--amazed me when I was a kid with some of their tricks. For lube, they always used Go-Jo. I really thought that was neat. Later in life, I began working on cars & used lots I'd learned by having watched them. Even then, there were a few butt-kickers I'd end up taking to them, about 35 miles away. First case I recall was a 1969 F-100 w'shield w/chrome insert. They did it; even they had to use all 3 men--papa & both grown sons! ![]() |
#15 |
I just had mine done. I tried to do it but got pissed that it wouldn't go in right. So I called a glass company and they did it along with my new front windshield.
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
#16 |
Senior Enthusiast
I did decide to go with the chrome locking bead. Unfortunately I ran out of decent weather so I'm going to wait until the spring for the install. The new gasket/bead lock is currently resting warm and comfy under the bed. It should be really simple. Since my current gasket is only 10 years old and in great shape, I'm just going to pull the black bead lock out and replace it with the chrome version and leave the gasket alone.
