Closed Thread
Old 11-22-2012, 04:08 PM   #5376
kaycee
kaycee's Avatar
Re: What did you do to your truck today!
Finished the install of my 60/40 Tahoe seats
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline
Old 11-22-2012, 04:16 PM   #5377
67Slider
67Slider's Avatar
Let's see em'. I have some I've yet to install.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 11-22-2012, 04:23 PM   #5378
ChillWinstonC20
ChillWinstonC20's Avatar
Uneasyrider, looks like you've got the most important tools out and in use...
ChillWinstonC20 is offline
Old 11-22-2012, 10:58 PM   #5379
Jimbabwe
Jimbabwe's Avatar
Technically this was yesterday, but you get the idea.
Jimbabwe is offline
Old 11-22-2012, 11:24 PM   #5380
kaycee
kaycee's Avatar
I'll try and get some pics friday
2005 FXDWG stage3
63 IMPALA 327/4L60
kaycee is offline
Old 11-22-2012, 11:34 PM   #5381
ChillWinstonC20
Went shopping yesterday. New wires, plugs and guides tomorrow.
Old 11-23-2012, 06:13 PM   #5382
UNEASYRIDER
UNEASYRIDER's Avatar
Yes Sir. A little liquid to get the job done!
DON'T BUILD IT IF YOUR NOT GONA DRIVE IT!!
UNEASYRIDER is offline
Old 11-23-2012, 07:38 PM   #5383
VDOG
Grand PooBaa Member
VDOG's Avatar
Like how this sits, is it static or an airbag drop?
VDOG is offline
Old 11-23-2012, 07:52 PM   #5384
Jimbabwe
Jimbabwe's Avatar
Thank you. It's bagged, with Porterbuilt front and rear. Finishing it up now. Driveshaft, etc...
Jimbabwe is offline
Old 11-23-2012, 07:56 PM   #5385
Jimbabwe
Jimbabwe's Avatar
Sorry, I forgot. Here's my link with a little info if you were thinking of going that route with your stepper.
http://67-72chevytrucks.com/vboard/s...d.php?t=545435
Jimbabwe is offline
Old 11-23-2012, 11:48 PM   #5386
midniteblues
midniteblues's Avatar
got my cm prepped for running the exhaust through it. I gotta cut the tubes a lil' shorter before welding them in. I just might cut one in half and use the two halves.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline
Old 11-24-2012, 12:55 AM   #5387
Shyguy
Junior Member
Shyguy's Avatar
My son drove my '67 swb steeper out to my house in the country today, first time on the road since we just finished building it.
Just one slight problem, it died and would not start about 3 blocks from my son's house.
We went back to my son's and got some supplies and tools. He checked for spark-ok, checked for fuel at carb, none. He finally isolated it to the tank as being why there was no fuel getting to the carb. He removed the pickup tube/sending unit and found that the sock had broken apart and plugged the pickup line.
Got the line all cleared out and away we went, it got home ok.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline
Old 11-24-2012, 01:04 AM   #5388
CMH77
Today I yanked the old, dead I6 250 out of the engine bay. Tomorrow I hope I will be posting that the new, healthy I6 250 is put together from breather to oilpan and back in the truck.
CMH77 is offline
Old 11-24-2012, 01:17 AM   #5389
allchevy58
allchevy58's Avatar
Got dash back together, new ac vent hoses, new vacuum hoses on heater/ac control, new fan switch, new speaker, installed underdash lights and glovebox light purchased from forum member, new glovebox cardboard, installed blue leds in cluster, radio and heater/ac control unit. Installed new fan shroud also purchased from forum member.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline
Old 11-24-2012, 03:15 AM   #5390
Andy4639
Old member
Andy4639's Avatar
Cool Re: What did you do to your truck today!
Well I got the SS steering wheel mounted and the new air horns work great with the new horn button.
I installed a set of the Chevy horns a few weeks back.
Can you hear me now! I think so.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Andy4639 is offline
Old 11-24-2012, 04:28 AM   #5391
bk2life
got more parts in the mail!! woohooo
bk2life is offline
Old 11-24-2012, 01:19 PM   #5392
kaycee
kaycee's Avatar
Heres the seats 60/40 split 99 Tahoe seats ,good junkyard find ($100)
2005 FXDWG stage3
63 IMPALA 327/4L60
kaycee is offline
Old 11-24-2012, 01:34 PM   #5393
69GWC
Wow $100 bucks :O man crazy good price and looks great.
69GWC is offline
Old 11-25-2012, 12:11 AM   #5394
Mayo
Cool Truck
Mayo's Avatar
Finally wired up the reverse lights to my LED lightbar
1968 Chevrolet C20 Longhorn "Cool Truck"
1937 Chevrolet Pickup - Project
Looking for a patina'd 68 50th Anniversary longbed
Mayo is offline
Old 11-25-2012, 12:42 AM   #5395
romeer1
romeer1's Avatar
Painted my frame and re-installed brake booster.
Superman
romeer1 is offline
Old 11-25-2012, 01:00 AM   #5396
VDOG
Grand PooBaa Member
VDOG's Avatar
Thanks for the link. I was going to pull a trailing arm setup from the wrecking yard, just did not know if I needed the complete rearend, or just the arms and u-bolts.
VDOG is offline
Old 11-25-2012, 02:57 AM   #5397
AustinScott
AustinScott's Avatar
I found some good deals around Town on some truck parts.
Bought a new cowl hood....
Also ended up bringing home a new TV.....
68-SWB, 327, hooker headers, spintec mufflers, disk brake 3.5/5 drop, buddy buckets, 200-4R, 2200 stall, 3.73 12bolt Eaton Posi,
My 68-SWB Photo Build Thread
All my Google Albums
AustinScott is offline
Old 11-25-2012, 11:59 AM   #5398
Dano69c10
Dano69c10's Avatar
... I was going to pull a trailing arm setup from the wrecking yard, just did not know if I needed the complete rearend, or just the arms and u-bolts.
Hey Vince,
I have a rear axle, trailing arms, u-bolts, shock crossmember, shock mounts and anything else you need to convert from leafs to coils.
Dano
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline
Old 11-25-2012, 04:05 PM   #5399
sumtercleaner
sumtercleaner's Avatar
Many mods to make tahoe seats work? Any more leg room under sterring wheel?
sumtercleaner is offline
Old 11-25-2012, 09:43 PM   #5400
UNEASYRIDER
Used left over seat material for my sub box
Closed Thread
