Old 11-23-2012, 05:25 PM   #1
shawno72
C/10 junkie
shawno72's Avatar
Re: Brand new 71-72 front brake hoses
shawno,... why aren't you using these?
I saw your other thread wanting conversion hoses, so I am confused.
Well after reading your info page I thought thats what I needed. I plan on keeping the original 68 brake lines and didn't want to run adapters. Am I wrong?
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 11-23-2012, 07:41 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
If you are doing the conversion and have to buy hoses I recommend the conversion hoses.
Since you already own the 71-72 hoses I would use those.
(they will be slightly longer since they don't have to reach all the way to the front of the crossmember to connect to the steel line)
Have you looked to see if you can bolt these directly up?
Inverted flare adapters will cure that and are around $5 each here locally.
I understand wanting to plan out your build before you start,... but it just might pay to look under your truck and check.
Didn't mean to upset your for sale thread.
Keith
Convert to disc brakes.
