Old 11-23-2012, 09:36 PM   #351
gdavis
gdavis's Avatar
Re: Rustbuket 67 build "Georgia"
Originally Posted by 67c10rustbuket View Post
Pic
I can see the up grade on the spring holders. Mine did not have the nuts only a hole. I did not thing of welding nuts like you did . I used a long bolt and lock washer and nut.
gdavis is offline   Reply With Quote
Old 11-23-2012, 09:48 PM   #352
El Campo
El Campo's Avatar
Loving what you did on the rearend. Looks great. Also good idea on the spring holders.
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
Old 11-23-2012, 09:59 PM   #353
oldman3
oldman3's Avatar
Nice job...Jim
oldman3 is offline   Reply With Quote
Old 12-14-2012, 06:39 PM   #354
Portmod7
Portmod7's Avatar
Lots of hard work on this one, great job so far!
Super Blue - 1968 C-10 Short Stepside
Fastburn 385, 4-Speed Sag. on the Column, Coleman 9" Floater w/Detroit TrueTrac
Portmod7 is offline   Reply With Quote
Old 12-14-2012, 10:31 PM   #355
suspect
suspect's Avatar
I wish I was as meticulous as you are with your build. I get to impatient.
I'm going to assemble my engine Christmas weekend, I'll swing by sometime within the week to borrow those tools.
Daniel
68 C10 Build http://67-72chevytrucks.com/vboard/s...d.php?t=503594
Romans 10:13 Everyone who calls on the name of the Lord will be saved.
suspect is offline   Reply With Quote
Old 12-14-2012, 11:11 PM   #356
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Ok Dan, what's the secret to posting a pic with the iPhone?
Zoomin is offline   Reply With Quote
Old 12-22-2012, 10:34 PM   #357
67c10rustbuket
67c10rustbuket's Avatar
Originally Posted by MJs69CST View Post
That housing looks great!!
Thanks MJ!
Thanks, I wonder why they had them welded on one end and not the other. After fighting getting them off I though this would be a good idea.
Thanks, I love the fancy welding job you did on your axle tubes, now that was slick.
Originally Posted by oldman3 View Post
Nice job...Jim
Thanks Jim!
Thanks, I love your project. All the fancy race car parts and the 4ott setup still blows my mind. You definitely think outside the mail order catalog.
Cool brother, I think lack of money breeds patience and meticulousness I try to do the best I can with what I have. Good thing I have you so I can recycle your old stock parts
Not sure, I just did as I do from my macbook. submit reply>manage attachments> my photo album opened up and I selected the photo and it worked. maybe dumb luck. Kind of a pain to navigate on that tiny little screen. Another thing I have the Iphone4 (because i'm cheap and it was free) its camera is a 5 megapixel while the Iphone5 has an 8 megapixel camera so the file size may have something to do with it. I love your new project!!
Update with pics coming right up!
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 12-22-2012, 10:37 PM   #358
67c10rustbuket
Okay I re-re-did my patch job welding on the frame and cut some box plates with our plasma at work, welded them in.
Dan <---(my name)
Old 12-22-2012, 10:39 PM   #359
67c10rustbuket
Frame boxing and smoothed, primer...
Dan <---(my name)
Old 12-22-2012, 10:42 PM   #360
67c10rustbuket
I painted all the overlapping surfaces with flat black and torqued the front suspension crossmember and trans crossmember to the frame. I used the assembly manual and it says 55-75 lbs ft so Itorqued them to 70 lb ft. I could not find anything for the trans crossmember and the bolts included by GMC Pauls are grade 5 so I left them at 40 lb ft untill I find some other specs.
Dan <---(my name)
Old 12-22-2012, 10:45 PM   #361
67c10rustbuket
First coat of paint. I am going to repaint the front crossmember gloss like the rest but I did not paint in front of it or the rear past the shock crossmember because I have more welding to do....
Dan <---(my name)
Old 12-22-2012, 10:48 PM   #362
67c10rustbuket
Second coat. This is Tractor Supply farm and implement paint, alkyd enamel. Thick, hard, and shiny! Had my frame been in better shape and if I had fixed all the little problems before I would have much rather had it powdercoated, live and learn. It was getting dark so the pics are pretty poor as far as the lighting goes.
Dan <---(my name)
Old 12-22-2012, 10:53 PM   #363
67c10rustbuket
I also cut the rivets for the pan hard (or track bar, what ever you want to call it), the shock mounts, and the front cross member so I can mount my sway bar brackets and I managed to fubar that job so the crossmember will be coming out so I can remove whats left of the rivets. I will be opening boxes of NEW parts very soon and ordering some more, next order will be a tracking bar from Porterbuilt
Dan <---(my name)
Old 12-22-2012, 10:57 PM   #364
es67chevy
es67chevy's Avatar
Glad to see it moving forward. Looks like some fine work there!
Eric
1967 C10 SWB
383 Stroker/TH400
Brother's One Piece Power Windows
Shaved Doors, Markers, and Bumpers
4/6 Early Classic Drop
Rear Fuel Tank (49-52 Chevy Car Tank)
Surf Blue Paint
Bella Vista, AR (Arkansas for those that get the 'A' states mixed up)
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=330869
es67chevy is offline   Reply With Quote
Old 12-22-2012, 11:39 PM   #365
67c10rustbuket
Thanks Eric, slowly but surely!
Is that implement paint sprayed on or brushed? Looking nice!!
Mmmmm Both, Originally I started with rolling and brushing with matte black then decided I liked the gloss better. I was going to use my spray gun but researched the paints msds and could not find any chemical difference in spray can vs quarts so I did the gloss in spray cans (convenience issue). The front suspension crossmember is 100% brush/roller. it does level out well, not quite as good as POR15 but it does level and takes quite a while to dry. You can tell it is different when the gloss dries it looks and feels like POR, you can tell how thick and hard it is not at all like regular rattle can paint. I can get a pic of the part I rolled tomorrow in the sun if you like.
http://tsc.tractorsupply.com/search#...&sliredirect=1
Dan <---(my name)
Old 12-23-2012, 12:08 AM   #366
bjcaldwe
bjcaldwe's Avatar
Looks good Dan. I think i will try that paint on mine. Does it come in any other colors than black?
My AD Truck Build Thread
52 GMC one day laying on the running boards
2004 Chevy Crewcab. 3/5 and notched
bjcaldwe is offline   Reply With Quote
Old 12-23-2012, 12:18 AM   #367
67c10rustbuket
Yep, many colors, OE tractor colors. Ford/ new holland blue, Caterpillar yellow, Red, green, silver, etc. pretty stinky stuff
Dan <---(my name)
Old 12-23-2012, 12:30 AM   #368
bjcaldwe
bjcaldwe's Avatar
I worked on mine a little today. Maybe soon I can get a few parts on the frame to the paint stage.
Old 12-23-2012, 12:41 AM   #369
oldman3
oldman3's Avatar
Frame is looking great, nice job...Jim
Old 12-23-2012, 01:01 AM   #370
Zoomin
Man of Mini-Talents
Zoomin's Avatar
All those neat colors and you went with black?!?
Posted via Mental Telepathy
Old 12-23-2012, 01:15 AM   #371
67c10rustbuket
I was thinking John Deere green would clash with the blue exterior paint Maybe Caterpillar yellow like our fork lift at work would match, better consult the wife. My daughter thinks I should paint it purple (yuck) I guess I am a pretty safe boring honkey so a black frame it is. I want to paint the trailing arms, control arms, pan hard, and sway bar a silver or charcoal grey. I will call you next week about that seat... Can I have your biscayne now that you are done with it ?
Dan <---(my name)
Old 12-23-2012, 09:53 AM   #372
mcbassin
Still Learning
mcbassin's Avatar
Looking good Dan! Keep the pics coming
Old 12-23-2012, 11:33 AM   #373
suspect
suspect's Avatar
Frame looks good.
Daniel
Old 12-23-2012, 11:39 AM   #374
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
Looking good!
72 chevy swb
Direct dealers for..
Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body..
Kyle
http://67-72chevytrucks.com/vboard/s...d.php?t=574629
screaminchevypickup is offline   Reply With Quote
Old 12-23-2012, 12:21 PM   #375
El Campo
El Campo's Avatar
Looks good! I made the mistake of painting a frame yellow one time........ Ended up sandblasting that amarillo crap off and painting black later hahaha
Hook em Horns!!!
