Old 11-23-2012, 09:56 PM   #751
ricott
Re: Lurker OrrieG Progress Pics
An s-10 stepside bed has a gas line buldge that would look stock.
ricott is offline   Reply With Quote
Old 12-19-2012, 11:51 PM   #752
6BT 56
6BT 56's Avatar
Hi Orrie.
What can you tell me abt the power brake booster you used? I think I will deffinately want to upgrade to power brakes now.
6BT 56 is offline   Reply With Quote
Old 12-20-2012, 12:13 AM   #753
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
You might consider hydro boost also.
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 12-20-2012, 01:47 AM   #754
OrrieG
OrrieG's Avatar
It is a 9" aftermarket unit I got from Performance On Line (POL). Generic hotrod type that accepts GM master cylinder. I use a 74 truck MC disc/drum and proportioning valve. Because of the 4wd it sits high enough check valves are not required.
Old 12-20-2012, 11:54 AM   #755
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
Look at the hump for an 86 k5 for the filler.
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
Old 01-24-2013, 05:47 PM   #756
lynx5653
lynx5653's Avatar
Originally Posted by OrrieG View Post
This shows the drivers side hinge welded in and then primed after grinding. Passenger side were the lower bolt recess was replaced, with the hinge installed to check alignment, its right on. Saturday night I had a light bulb moment realizing that the cab corners would be open to the atmosphere unless I closed the opening at the inside corners. I remembered that before I took it off the road there was a lot of exhaust fume smell, now I realize with the mufflers dumping right behind the cab the exhaust was leaking up through the rusted out inner corners. I made a cardboard template, transfered it to metal and spot welded it in. I picked up some 3M body seam sealer at the body shop and will seal all the seams for a air tight fit. Sound insulation and carpet will finish it up. I'm also sealing all of the seams under the cab before I under coat it.
Did you make this part for closing up the gap inside cab for the corners ? I have those same pieces in my cab thought they were factory covers. mine were screwed down with clutch head screws making me think the were factory installed. I plan to reuse them in anycase, had to remove them to clean out all the sand from blasting they werent sealed tight.
1955 2nd on 86 chassis
Daily driver
lynx5653 is offline   Reply With Quote
Old 01-24-2013, 06:39 PM   #757
OrrieG
OrrieG's Avatar
I made mine. I looked in the Factory Manual and it does not show up. I got my truck in 76 from the second owner so I know it was relatively original. A previous owner of yours, or maybe even dealer, figured out the problem and made the plate. Patrick
Old 01-24-2013, 07:12 PM   #758
lynx5653
lynx5653's Avatar
Maybe guy I got it from read your build thread, who knows.
What are you using for wheels ? My wife wants a wheel that will look good with whitewall tires, any suggestions. My truck has 72 4x4 running gear.
Daily driver
Old 02-03-2013, 04:47 PM   #759
wyomech
wyomech's Avatar
Just read through your build ,its funny how much different people have in common.I bought my 56 back in 1976 and used it for my daily driver,finally pulled the 327 out 2 years ago and put in a 6.0 and overdrive.I wanted to make it 4x4 but ended up converting a 63 swb instead. I also have a 64 malibu that I drive a lot. I like your attitude about building your vehicles to drive them.I am also running a SP2P manifold and the old style valve covers on the chevelle.
wyomech is offline   Reply With Quote
Old 02-04-2013, 02:32 PM   #760
wyomech
wyomech's Avatar
Check out the february Hemmings Motor News they have a article on a 59 4x4 beautiful original .
Old 02-04-2013, 03:55 PM   #761
OrrieG
OrrieG's Avatar
lynx, I am going to run the stock 74 16" steel wheels painted to match the body color with trim rings and these hub caps (68-74 truck). Still debating how big or tires to run.
Wyomech the similarities are great, I know some local people that have both a TF or AD truck and 64-68 Chevelles too. Seems to be a good combination. I will check out the article, I assume its a NAPCO. I think 59 was the first year you could get them off the factory line, not as a dealer conversion.
Old 02-04-2013, 09:19 PM   #762
lynx5653
lynx5653's Avatar
thanks for info on wheels,they will look great.
My wife likes these rims just not sure if I can make center caps work.Name:  wheels..jpg
Daily driver
Old 02-04-2013, 09:41 PM   #763
dubie
dubie's Avatar
I'm using these same wheels on my 56 step side build
Here's a cool video with a 56 wearing a nice set of ralleys
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 02-04-2013, 11:39 PM   #764
dubie
dubie's Avatar
Old 02-10-2013, 05:12 PM   #765
OrrieG
OrrieG's Avatar
To do list is down to three pages! But still to cold for body work, wiring, etc. Garage is 45 with stove going, wifes greenhouse is 70+ with just the sun working. Did get some general cleaning and organizing done so I can hit it hard when it warms up.
Old 02-10-2013, 06:22 PM   #766
oldman3
oldman3's Avatar
That's a long list, but I know you will knock out a lot of them in a hurry....Jim
oldman3 is offline   Reply With Quote
Old 02-11-2013, 02:31 PM   #767
_Ogre
_Ogre's Avatar
move your truck into the greenhouse
your wife will understand
shop air compressor timer
Old 02-11-2013, 08:44 PM   #768
OrrieG
OrrieG's Avatar
I built the greenhouse and garden shed to get all her outdoor stuff out of the shop. Now if I could just recapture some of the space in the shop attic that is used for crafts, grandkids toys, etc.
To many trees to add one to the shop, but when I re-roof I am looking at adding some skylights.
Old 02-11-2013, 11:18 PM   #769
6BT 56
6BT 56's Avatar
Hi Orrie
im just abt to mount my stering box same as yours. some where in your thread you have full measuremeants and a pdf attached. you have 31 pages now ! i cant find it .
Can you pls re post some info . or post it on my build .
Thanks .
keep up the good work .
56 gmc 4X4 Cummins 5 spd 60F 70R
2005 Ram 3500 DRW cummins 4X4.
2006 Conolift 9/15. 2011 F 350 winter beater
New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new !
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908
Old 02-17-2013, 10:07 PM   #770
OrrieG
OrrieG's Avatar
Decided its warm enough to start wiring. Here are the two diagrams I made. One is the FAM wiring blown up to 24" x 36" size. Other is same size with the EZ wire diagrams placed in relationship to the truck layout, other information, and lots of notes. I have at least 8-12 hours in on just the research and thinking part.
I laid out the fuse panel and wires as they came from EZ on two 8' tables we use for camping, right next to the truck. Then starting with the back section, dash, column then front checked every wire, rearranged some, discarded some then retied them into logical (in my mind) groups according to how I am going to run them. That part took 6 hours today.
EZ was pretty close, but it is still not just uncoil it and go. I still have about 10 wires for stuff I am not going to use, but may need for other things in the future that need to figure out. I also need to get some relays, power distribution block, extra wire that did not come in the kit and fusible link wiring, and loom material. Before I used the split ribbed stuff but found it gets dirty and hard to clean real fast. Ok for places you can't see. I am leaning toward black spiral so I can easily pull wires out as I go but still protect the wires.
Good to be making progress again.
Old 02-18-2013, 12:55 AM   #771
Kim57
Kim57's Avatar
I can't wait until I'm at that point.
Good luck with it.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 02-18-2013, 01:36 AM   #772
Daze57
Daze57's Avatar
wiring is always fun - good luck OrrieG - took me about 3-4 days but i was checkin things 5-6 times - i dont need no chevy flame up
i used the black spiral wrap also - works out v v well
Daze57 is offline   Reply With Quote
Old 02-18-2013, 07:25 AM   #773
dug224
dug224's Avatar
OrrieG: Great progress. Wiring is screaming up on my quickly. We CAN'T have too many photos of your wiring progress. Now that I have my cab off, I will study reusing as much OEM frame harness as possible since it is already there. Thanks Dug
dug224 is offline   Reply With Quote
Old 02-18-2013, 02:11 PM   #774
_Ogre
_Ogre's Avatar
looks good orrieg
i hear guys say that it took 3 or 4 days to wire their truck,
it took me over a month to add all the relays, alarm, remotes, pw, ps, ac, fan, latches, etc...
add your new motor requirements i see a lot of wiring in your future
be patient
Old 02-18-2013, 02:19 PM   #775
OrrieG
OrrieG's Avatar
Thanks guys. Orge, I plan on having another 16-20 hours in on it. My grandson who is now living with us told me last night that he is bored with video games and wants to get back helping on the truck so I will have a helping hand.
Dug, I would look carefully at your harness. It may look OK but the original wire outer plastic gets very brittle, especially if its been over loaded or hot. I found places where the shielding had started to just drop off and exposed the wires to shorting. A couple of time I had wires ground to the body or frame. I figured I was not going to spend years and thousands of dollars on this truck to save a few hundred and some hours and see it burn to the ground.
